Summary
Every TLS-terminated listener (IMAP/993, JMAP+HTTPS/443, SMTP submission) accepts the TCP connection and then closes it with zero bytes sent back — no TLS ServerHello, no plaintext banner, nothing — before any protocol handshake completes. This is not intermittent: it is 100% reproducible on every connection attempt, from every network path tested (public internet, host loopback, and container-to-container within the same Docker network).
The server has been in this state continuously. Docker’s own HEALTHCHECK (curl -k https://127.0.0.1:443/healthz/live) intermittently reports “healthy,” which is misleading — it is not representative of whether real protocol traffic (IMAP LOGIN, JMAP session, SMTP) can complete.
Environment
Deployed via the official stalwartlabs/stalwart Docker image, using the standard docker-compose.yml pattern from the Stalwart install docs (RocksDB backend, config.json as a datastore-pointer bootstrap file, all real config/domains/certificates stored in the RocksDB-backed registry).
Started on v0.16.12, running continuously for ~7 weeks before the fault was noticed.
Docker: docker compose v2, host is a standard Linux VPS (no unusual kernel/network config — verified: no fail2ban, no ufw, no custom iptables DROP/REJECT rules; iptables -L DOCKER-USER is empty; packet counters confirm inbound SYNs are correctly DNAT’d to the container).
What I ruled out, with direct evidence, before filing this
Resource exhaustion — checked /proc//limits and open FD count on the main process directly: 54 of 65,535 file descriptors in use. Memory ~360MB/7.7GB. CPU idle. Disk 17% used. None of these are close to any limit.
OS/network-namespace state — did a full docker compose down && up (not restart), which tears down and recreates the network namespace, port bindings, and iptables NAT rules from scratch. Identical failure afterward.
Binary version — upgraded from stalwartlabs/stalwart:v0.16.12 to :latest (resolved to v0.16.19) via the same procedure (down, swap image tag, up), same data volume. Identical failure on the new binary, immediately after a completely fresh process start.
Host firewall / connection filtering — fail2ban is inactive (not even installed as a running service), ufw is inactive, iptables -L DOCKER-USER -n -v is empty (0 rules), and the NAT table’s DNAT rules for 993/443/etc. show real packet/byte counters incrementing on test connections, confirming traffic reaches the container’s actual listening socket.
Certificate problems — used the built-in --console Data Store CLI to scan the SUBSPACE_REGISTRY (‘s’) keyspace directly (source-verified subspace byte from crates/store/src/lib.rs), extracted all 88 stored leaf certificates + chains (352 total BEGIN/END CERTIFICATE blocks), and decoded every one with openssl x509 -noout -subject -ext subjectAltName -dates. Findings:
No expired certificates. All notAfter dates are in the future relative to server time.
No duplicate/conflicting certificates for the same SAN set (checked specifically, since this pattern is described in a support thread as a known failure mode — not present here).
The specific certificate needed for the actual IMAP/JMAP hostname (CN=mx1.maillan.com, SAN mail.maillan.com, mx1.maillan.com) is present, singular, and currently valid (notBefore=Jul 9 2026, notAfter=Oct 7 2026).
A server.proxy.trusted-networks misconfiguration — this failure signature (connection accepted, then dropped silently expecting a PROXY-protocol header) is described in Stalwart’s own troubleshooting docs as an exact match. I searched the registry keyspace for any literal or namespaced form of this setting — nothing found. This deployment has no reverse proxy in front of Stalwart’s own published ports (Caddy in this stack only proxies two unrelated services on different ports; Stalwart’s 443/993/etc. are published directly).
No visibility from logging, at any level — this is the part I can’t get past without your help:
docker logs stalwart has been completely empty since the container was first created 7+ weeks ago (0 lines), across both v0.16.12 and v0.16.19.
Re-ran the server attached, with RUST_LOG=trace and RUST_BACKTRACE=full explicitly set, on a fresh container instance — made a real connection attempt against it — still zero stdout/stderr output, before or after the failed connection.
Checked whether telemetry/tracing is instead being written to Stalwart’s own internal store (SUBSPACE_TELEMETRY_SPAN, byte ‘o’, per crates/store/src/lib.rs) — scanned that entire keyspace directly via the console — it’s completely empty. Tracing does not appear to be enabled by default, and I have no way to enable it (the WebUI/JMAP admin API needed to configure it is the exact thing that’s unreachable due to this bug — a hard catch-22).
What this points to
Given the data is verified clean and the fault survives both a full environment recreate and a version upgrade, this looks like a runtime-level fault in how the server handles TLS/connection setup against this specific account/domain dataset (~280 mailboxes, ~20 domains with Automatic ACME certificate management via Let’s Encrypt, TlsAlpn01 challenge type) — not a configuration or data-corruption issue on my end. I’m not able to narrow it further without either the WebUI (blocked by this exact bug) or guidance on capturing meaningful diagnostics for a genuinely silent failure like this.
What would help
Is there a way to force verbose logging to stdout that doesn’t depend on RUST_LOG/RUST_BACKTRACE (e.g. a config value that must be set inside the RocksDB-backed config itself, which I can’t reach right now)?
Is there a known failure mode where a large number of Automatic-managed ACME domains (each with 3 auxiliary SANs: mta-sts., autoconfig., autodiscover.) could cause the TLS acceptor to hang/panic per-connection during certificate selection, in a way that wouldn’t show up as data corruption?
Any recommended way to safely inspect/repair this from the CLI/console alone, without the WebUI, given the exact SUBSPACE_REGISTRY key structure for Certificate/Domain objects (I reverse-engineered the subspace byte from source but not the full object-key encoding within it)?
Happy to provide anything else — I have a full backup of the RocksDB data taken immediately before any of this troubleshooting, plus the complete decoded certificate inventory, if that’s useful for reproduction.
