V1.0.0: A yearless BDAY that Stalwart serves as vCard 3.0 (–03-15) loses its day when it is uploaded again, and is then written as –3
On v1.0.0, with AddressBook.vCardVersion set to v3, Stalwart serves a birthday without a year as BDAY:–03-15. When a client uploads that same value in a vCard 3.0 card, Stalwart stores only the month and drops the day. The PUT returns 201 and nothing is logged. The month-only date is then written as BDAY:–3 in both 3.0 and 4.0. So a 3.0 client that saves back a card it got from Stalwart (for example after the user edits another field) silently loses the day of a yearless birthday. We set v3 because iPhone Contacts never asks for a version and reads 4.0 as Latin-1 (t/405).
Stalwart reads back the value it writes: BDAY:–03-15 in a 3.0 card is stored as month 3, day 15 and served again as --03-15 (3.0) or --0315 (4.0). A month-only date is written zero-padded, --03, as in the RFC 6350 §4.3.1 examples.
Uploaded
Served as 3.0
Served as 4.0
3.0, BDAY:–03-15
BDAY:–3
BDAY:–3
3.0, BDAY:–0315
BDAY:–03-15
BDAY:–0315
4.0, BDAY:–0315
BDAY:–03-15
BDAY:–0315
3.0, BDAY;X-APPLE-OMIT-YEAR=1604:1604-03-15
unchanged
…:16040315
The first row is the problem: its input is exactly what rows 2 and 3 serve as 3.0. Apple’s own form in row 4 round-trips correctly (fixed with t/2000).
In the source at v1.0.0: push_legacy_vcard writes a month and day without a year as --MM-DD (crates/calcard/src/vcard/writer.rs:465-470). On upload, parse_vcard_date_legacy (vcard/parser.rs:749) needs a full year-month-day, so --03-15 falls back to parse_vcard_date (lines 868-877). That function reads 03 as the month, then reads the day with parse_small_digits(…, false), which stops at the - before 15. The rest is ignored and the date is not null, so it counts as a successful parse. The month-only arm (None, Some(month), None) in both writers uses push_u64 instead of push_2_digits (writer.rs:369-371 and 478-480), hence --3.
A possible fix: accept the - before the day in parse_vcard_date, and use push_2_digits in both month-only arms. Optionally, write a yearless 3.0 date in Apple’s X-APPLE-OMIT-YEAR=1604 form, which Stalwart already round-trips, since RFC 2426 has no truncated dates.
Set AddressBook.vCardVersion to v3 and restart.
PUT to /dav/card//default/probe.vcf:
BEGIN:VCARD
VERSION:3.0
UID:probe
FN:Probe
N:Probe;;;;
BDAY:–03-15
END:VCARD
GET the card with no Accept header → BDAY:–3.
GET it with Accept: text/vcard; version=4.0 → BDAY:–3.
Repeat with BDAY:–0315 instead. GET with no Accept header returns BDAY:–03-15, which is the value from step 2.
v1.x
OIDC
Found with curl against v1.0.0; the only relevant setting is AddressBook.vCardVersion = v3. The configuration is applied as JMAP objects with stalwart-cli apply. We have not checked yet whether iOS Contacts sends --03-15 back unchanged.
Your source reading matches what I found in the current tree. I haven’t run the reproduction.
In crates/calcard/src/vcard/writer.rs, both month-only arms (None, Some(month), None) write the month with buf.push_u64(month.into()). That is at lines 369-371 and 478-480. It explains why --03 comes out as --3.
The parser side is also where you said. PartialDateTime::parse_vcard_date_legacy is at vcard/parser.rs:749. I only read its signature, not the fallback into parse_vcard_date. I haven’t confirmed how that function handles the - before the day, so the “stops at the -” part of your diagnosis is still unchecked by me.
The docs don’t cover this, so I can’t give a documented answer or workaround. This looks like a real round-trip bug, and the two fixes you suggest are the obvious candidates. They are accepting --MM-DD in the fallback parser, and zero-padding the month-only output with push_2_digits. A human will follow up here.
The day was lost in the date parser: parse_vcard_date read the month of --03-15, stopped at the - before the day, and still treated the result as a valid date, so a 3.0 client saving back what we served lost the day without any error. The month-only writer arms used an unpadded number, which is where --3 came from.
Both are fixed: --MM-DD is now read as month and day in 3.0 and 4.0 cards, and a month-only date is written as --03. I kept --MM-DD as the 3.0 output and didn’t switch to the X-APPLE-OMIT-YEAR=1604 form, because other 3.0 clients would then show the year 1604. The fix ships in next week’s release.
Cards that already lost the day were stored as month-only, so those birthdays need the day entered again once you’re on the new version.
