On a server hosting multiple domains, JMAP VacationResponse auto-replies are DKIM-signed with the domain of the server hostname instead of the domain in the From: header, breaking DMARC alignment. Server hostname is mx.example.net; the account sends as [email protected], a second hosted domain with p=reject. Active, published DKIM signatures exist for both domains.
dkimSignDomain on SenderAuth is at its default: is_local_domain(sender_domain) && !is_empty(authenticated_as) → sender_domain, else false.
A vacation response has no authenticated session, so authenticated_as is empty and the expression evaluates to false — the message should not be signed at all. If it is signed, the signature should use the From: domain (example.com), for which valid signatures are configured.
The message is signed regardless, and with the hostname domain:
Message-ID: [random]@localhost
DKIM-Signature: v=1; a=ed25519-sha256; s=v1-ed25519-[hostname-selector]; d=example.net
DKIM-Signature: v=1; a=rsa-sha256; s=v1-rsa-[hostname-selector]; d=example.net
Regular submissions from the same account are signed correctly with d=example.com and carry Message-ID: [random]@example.com — verified for both SMTP submission and JMAP. So this code path appears to bypass dkimSignDomain entirely rather than honouring it, and to build the response without the account’s sending identity in scope.
Receivers report dkim=pass [email protected] alongside header.from=example.com, i.e. DKIM is not aligned. DMARC only passes because the envelope sender is aligned and SPF holds; on any forwarding path the auto-reply is rejected.
- Host two domains on one server; the hostname belongs to the first domain.
- Create and publish DKIM signatures for both domains.
- Leave dkimSignDomain at its default.
- Enable a JMAP VacationResponse on an account sending as the second domain.
- Send a message to that account from an external provider and inspect the auto-reply headers.
Reproduced against two independent receiving providers.
These auto-replies also use the account address as envelope sender instead of an empty one (RFC 3834 §5), which has already triggered an NDR from a remote system. Worth fixing together — correcting only the envelope sender would move SPF evaluation to the HELO identity, which is equally unaligned, and every auto-reply from a p=reject domain would then be rejected outright instead of only on forwarding paths.
