Vandelay 1.0.14 - import via exchange-ews uses the mailbox from --auth-basic and not from --mailbox
Hi everyone!
Checking in to see if I hit a bug or doing something wrong.
I am running vandelay 1.0.14 with the following options:
vandelay import exchange-ews --url https://XXX.XXX.XXX.XXX/EWS/Exchange.asmx --allow-invalid-certs --mailbox [email protected] --mailbox-kind primary --auth-basic XXX/XXX db.sqlite
The issue I am having is that the default mailbox of the user used in --auth-basic is imported and not the mailbox set via --mailbox.
The user used for --auth-basic has FullAccess on the Exchange for the mailbox set via --mailbox and can manage the mailbox without issues within Outlook.
This looks like expected behaviour rather than a bug, going by the docs. I couldn’t find anything saying that --mailbox switches the mailbox under Basic authentication.
The EWS importer docs only describe Vandelay acting on the mailbox named by --mailbox through Exchange impersonation in the application-only flow. That is --auth-bearer with --ews-client-secret and --ews-client-id. With --auth-basic, --mailbox is only used to give Vandelay the mailbox’s SMTP address when it can’t work it out from the credentials. Your Basic user (XXX/XXX) isn’t an address, so the address is needed, but that doesn’t make Vandelay read someone else’s mailbox. FullAccess is also something Outlook handles by opening the extra mailbox as a separate store. It doesn’t carry over to a plain EWS request made as the Basic user.
I can’t confirm from the docs whether Basic authentication with delegate or impersonation access is supported, so a human will need to confirm that. Two things that might help in the meantime:
  • If your Exchange Server accepts OAuth, use the application-only flow with --auth-bearer --ews-client-id ... --ews-client-secret .... The application needs permission to access the target mailbox.
  • Otherwise, run the import with the target mailbox’s own credentials in --auth-basic.
Please also post the first lines of the run output, or the mailbox recorded in the archive, so others can see which mailbox was actually read.
This was a bug in Vandelay. With Basic authentication, --mailbox was only used for Autodiscover and as a routing hint; the folder requests themselves didn’t name a mailbox, so Exchange answered them from the signed-in user’s own mailbox. Full Access was never the problem. Worse, the archive got recorded under the --mailbox address even though it held the other user’s mail.
Vandelay now addresses every folder in the mailbox given by --mailbox, which is exactly what Full Access permits. The fix ships in the next Vandelay release (1.0.15), and your command will work unchanged. Start from a fresh db.sqlite, though, because the current one contains the wrong mailbox.
