When x:InMemoryStore is a Redis/Valkey cluster, any slot migration
(failover, resharding) permanently breaks the rate limiter on every already-running
Stalwart node. The rate limiter issues a MULTI/EXEC pipeline, and in cluster
mode the MOVED redirects come back inside the EXEC response array rather than
as a top-level error, so redis-rs never refreshes its slot map. The pooled
connection keeps pointing at the old master indefinitely.
Only a restart clears it. Because the failures are intermittent — only keys in the
migrated slot range are affected — the node stays up and serves most requests,
which makes it easy to miss.
AI-disclaimer: i used an AI to help me figure out why things weren’t working, and what was the cause, and to formulate this issue
I expect stalwart to follow the redirect given by the valkey cluster, and not continue hammering the wrong shard.
redis-rs handles a top-level MOVED by refreshing the slot map and retrying, but
here both redirects are elements of the EXEC reply (Index 0 and Index 1 are the
incr and the expire), so no refresh is triggered.
This is not specific to MOVED. Any cluster-level condition surfaces the same way
and is equally unrecoverable — ReadOnly: You can't write against a read only replica after a demotion, and ClusterDown: The cluster is down while a cluster
is reorganising, both wrapped in the same Transaction aborted and both from the
same call site.
Nothing else recovers it either: the deadpool manager in
crates/store/src/backend/redis/pool.rs only issues PING in recycle, and a
stale-but-healthy node answers that normally, so the connection is never discarded.
- Run Valkey in cluster mode with at least 3 shards and 1 replica per shard.
- Point
x:InMemoryStoreat it asRedisCluster, start Stalwart, confirm no errors. - Trigger a failover on one shard —
valkey-cli cluster failoveron a replica is
enough; no node needs to die. - Generate traffic that hits the rate limiter (any authenticated request will do).
ERROR Redis error (store.redis-error) listenerId = “http”, reason = “Transaction aborted:
[(Index 0, error: Moved: 8699 10.244.2.250:6379), (Index 1, error: Moved: 8699 10.244.2.250:6379)]”,
causedBy = “crates/store/src/dispatch/lookup.rs:111”,
causedBy = “crates/store/src/dispatch/lookup.rs:317”,
causedBy = “crates/common/src/auth/rate_limit.rs:82”
Elasticsearch
SQL
