A moved occurrence shows twice
that date shows once, at the new time.
it shows twice under the same id, at the old time and at the new time.
1 Upload a weekly event with SEQUENCE:0.
2 Add a change for one occurrence that moves it by two hours, with SEQUENCE:1.
3 Query the range with expandRecurrences: true.
in calcard src/icalendar/dates.rs (lines 78 and 148), a changed occurrence only replaces the normal one when both have exactly the same SEQUENCE number. The standard matches them by date (RECURRENCE-ID) only.
