I use a directory and added a second domain to my Stalwart.
Weird enough, on my domain tab it doesn’t allow me choose the directory to read from.
However, when authenticating from my e-mail client, it works normally and I can send and receive emails.
But when connecting to the /admin/login endpoint, I get this:
2026-05-30T11:33:54Z ERROR Authentication error (auth.error) listenerId = "https", localPort = 443, remoteIp = 10.11.11.111, remotePort = 52036, details = Authentication error (auth.error) { details = "Account does not have a password. If you are using an external directory, make sure to set the password attribute.", causedBy = "crates/common/src/auth/oauth/token.rs:59" }, causedBy = "crates/http/src/auth/oauth/token.rs:127"
What can be the problem?
FoundationDB
LDAP
Let me look into this error to give you an accurate answer.
The error is directly caused by the interaction between bind authentication and the WebUI’s OAuth token flow. Here’s what’s happening and how to fix it:
Root cause: Your LDAP directory is configured with bindAuthentication: true (which is the default). In this mode, Stalwart authenticates users by binding as them directly – it never reads a password hash from LDAP. However, there is a key requirement: the attrSecretChanged attribute must be properly mapped so Stalwart can track password changes and generate OAuth tokens for the WebUI login. If that attribute is missing or not returned by your LDAP server, the OAuth token path cannot find a “password” value and throws this error.
Things to check/fix in your LDAP Directory object:
attrSecretChanged – This attribute (default ["pwdChangeTime"]) must be present and returned by your LDAP server for entries. If your LDAP schema uses a different attribute name for password change timestamps, update attrSecretChanged to match. For example:
(Use whatever attribute your LDAP server actually populates for password change tracking.)
Alternatively, if bindAuthentication is false (service-account hash comparison mode), ensure attrSecret points to the correct attribute that stores the password hash (default ["userPassword"]), and that your LDAP server actually returns that attribute to the service account.
Why does IMAP/SMTP work but not the WebUI? Email clients authenticate via SASL mechanisms (PLAIN, LOGIN, etc.) which go through a different code path. The WebUI login uses OAuth token issuance, which is where Stalwart needs the password hash or password-change marker to issue a token – and that’s the step that’s failing.
You can configure these settings in the WebUI under Settings > Authentication > Directories, or via the stalwart-cli.
Relevant docs: LDAP Directory – specifically the “Authentication methods” and “Object attributes” sections.
The “Account does not have a password” error fires when the account is found but the directory returns no usable password for it, which for an LDAP-backed user means the directory being consulted is not the one holding that user. That lines up with your symptom: one tree’s users authenticate, the other tree’s users do not.
A couple of things to check. Choosing a different directory per domain is an Enterprise feature; in the community edition every domain resolves to the single default directory, so if the failing users live in a second LDAP that is not the default, the WebUI auth will not find their password even though IMAP/SMTP may resolve them differently. Also, there was a real bug in per-domain external directory resolution that was fixed in 0.16.7, so if you are on Enterprise and below that, upgrade first and retest.
To narrow it down: what exact 0.16.x version are you on, Enterprise or community, and is each domain meant to use its own LDAP or should one default LDAP cover both trees? Confirm the failing users’ bind returns a userPassword attribute.
The split you’re seeing lines up with how the two paths validate. IMAP and SMTP authenticate by binding to LDAP directly, so they succeed as soon as the bind works. The web UI login goes through the OAuth token flow, which additionally needs Stalwart to hold a password credential for the account; if the account was synced without a secret, that step fails with exactly this message even though the bind is fine.
So the likely cause is that the failing subtree’s entries don’t expose the password to Stalwart’s attrSecret mapping the same way the working ones do (a different objectClass or attribute, or a bind-only setup), so those accounts are materialised with an empty secret. Could you post your directory config (the filter/bind settings and the attrSecret / userPassword mapping, redacted) and note whether the two account types differ in schema? A debug-level auth trace for one failing web login would confirm it. Directory attribute docs are at LDAP Server | Stalwart .
Stalwart does bind, the same as Dovecot: with bind authentication on (the default) the password is checked with a simple bind against the user’s DN. So that part of your setup is fine, and it is why IMAP and SMTP work.
The asymmetry is on the OAuth side rather than the LDAP side. On 0.16.x before 0.16.8, issuing a refresh token (which is what the WebUI login does, unlike IMAP and SMTP) required Stalwart to hold a password credential for the account. In bind mode that credential comes either from userPassword, if the service bind DN is allowed to read it, or from a placeholder derived from the password-changed attribute. Yours is blank, so if the failing subtree’s ACIs hide userPassword from the bind DN there is nothing to store and you get exactly this error, while the working subtree exposes it.
Two things to do. Set the Password Changed Attribute to postfixPasswordChanged (your entries already carry it, I saw it in the LDAP dump you posted in the aliases thread), then do one IMAP login per affected account so it re-syncs. And upgrade to 0.16.8 or later, which removes the requirement altogether and is the durable fix. If you want to confirm the ACI theory first, run ldapsearch as your bind DN against one working and one failing account and see whether userPassword comes back for both.
