Add more description fields
It’s pretty difficult to distinguish the list items on “TLS certificates” or to tell what it is on “Milter filters”. It would be really helpful if there would be the possibility to enter a description on each item.
Here is an example of what I meant. Pretty difficult to select the right certificate between mail.example.de and mail.example.de (one ECC, but which one).
