Allow Directory Queries being ignored
In settings → Files & Sharing → Sharing “Allow Directory Queries” toggle is ignored, even after executing “Reload server settings”
When toggle is deselected, no other server addresses should be shown.
The toggle is unchecked but I can list all addresses in the server, even different domains (Using bulwark, and is specially visible when trying to share a calendar, it happens in ihasmail too)
Is any known issue?
I only was able to prevent that behaviour with custom role, I created a new role as Extended role from “User” and then adding “JMAP: Search for principals matching criteria” in disabled Permissions section.
in that case can’t list other accounts… as negative effect I can’t share anything neither (at least using included share option in this web clients)
Try to list principals using jmap client, ihashmail or bulwark in instance.
Go to a calendar and try to “share” you can then list all server email addresses.
MySQL
ihasmail v2026.9.3
bulwark (happens in all version from 1.92 to version 1.11.2)
This is fixed in v1.0.0. The fix can’t be backported to v0.16, but v1.0.0 will be released in late October or early November.
