I just installed a new Stalwart server, but now I’m having trouble adding my email in Thunderbird because it can’t find the auto-configuration. I haven’t been able to set it up manually either, since I keep getting a connection error. Now I’m not sure if it’s because of my DNS entry or the WARN message in the log.
WARN No TLS certificates available (tls.no-certificates-available) total = 0
The WARN message is the root cause. Stalwart has no TLS certificate configured, so all TLS-dependent services (IMAPS, SMTPS, STARTTLS, HTTPS) will fail to connect, and Thunderbird’s auto-configuration fetch will also fail if it is being served over HTTPS.
Both issues are connected: the tls.no-certificates-available warning is the root cause of all your connection errors and the broken auto-configuration.
The core problem is that no TLS certificate has been configured. Stalwart’s autoconfig/autodiscover endpoints are served over HTTPS (port 443), so clients cannot reach them – and cannot connect to IMAP/SMTP either – until TLS is working. The WARN you’re seeing confirms this directly.
Here’s what to do:
1. Set up a TLS certificate. The easiest approach is ACME (Let’s Encrypt). Go to Settings › TLS › ACME Providers in the WebUI, create an ACME provider, and Stalwart will obtain and renew certificates automatically. Alternatively, you can supply an existing certificate manually under Settings › TLS › Certificates by uploading the PEM-encoded certificate chain and private key. See the TLS Certificates docs and the ACME overview.
2. Check DNS for autoconfig. For Thunderbird’s Mozilla Autoconfig format, your DNS needs a CNAME pointing autoconfig.yourdomain.com to your mail host. For Microsoft Autodiscover, you need autodiscover.yourdomain.com. The newer PACC protocol requires no subdomain – clients fetch https://yourdomain.com/.well-known/user-agent-configuration directly. The WebUI’s domain management page will show you the exact DNS records to publish. See the DNS setup docs and the Autoconfig docs.
Once a valid TLS certificate is in place, the connection errors should resolve and autoconfig will start working for Thunderbird.
Since I have a reverse proxy running and automatic certificate generation isn’t working, I’m using manual certificate generation. I’m using the Let’s Encrypt certificate generated by Nginx Proxy Manager and adding the `fullchain.pem` and `privkey.pem` files there, but the error still occurs.
and it also shows me here that it’s a valid format
The tls.no-certificates-available total = 0 warning means Stalwart has
zero Certificate records that match the SNI the client is sending; the
listener falls back to a self-signed cert.
If you are certain that your reverse proxy is using a valid certificate you can ignore this error. However, you still need a valid certificate to serve IMAP/SMTP connections.
But what kind of domain does he need? Does he need mail.example.com or example.com? Right now, I’m trying to use a certificate for mail.example com.
TLS error: invalid peer certificate: certificate not valid for name “mail.example.com”; certificate is only valid for DnsName(“example.com”)
So my server has a certificate, but apparently it’s only for example(pot)com, even though I never added it there.
