Autodiscover answers ActiveSync (mobilesync) requests with HTTP 200 and an Outlook-schema body
POST /autodiscover/autodiscover.xml returns the same Outlook-schema response (IMAP/POP3/SMTP) whatever AcceptableResponseSchema the client asks for. A client that requests the ActiveSync schema (http://schemas.microsoft.com/exchange/autodiscover/mobilesync/responseschema/2006) gets HTTP 200 with a body it can’t use. Microsoft’s autodetect service then classifies the domain as Exchange ActiveSync. New Outlook for Windows stops autofilling the IMAP settings, and when the user picks IMAP or POP by hand it guesses imap.<domain>/pop.<domain>/smtp.<domain>.
Stalwart doesn’t implement ActiveSync, so a request whose AcceptableResponseSchema is the mobilesync schema should not get a successful reply. An Autodiscover error response or a non-2xx status would do. Clients and Microsoft’s autodetect service can then fall back to the IMAP/SMTP settings. More generally, a request for any response schema other than the Outlook one should not be answered with the Outlook body.
HTTP 200 with the Outlook response. The body is identical to the reply to a request for outlook/responseschema/2006a:
<Autodiscover xmlns="http://schemas.microsoft.com/exchange/autodiscover/responseschema/2006">
  <Response xmlns="http://schemas.microsoft.com/exchange/autodiscover/outlook/responseschema/2006a">
    <Account>
      <AccountType>email</AccountType>
      <Action>settings</Action>
      <Protocol><Type>IMAP</Type>...</Protocol>
      <Protocol><Type>POP3</Type>...</Protocol>
      <Protocol><Type>SMTP</Type>...</Protocol>
    </Account>
  </Response>
</Autodiscover>
Microsoft Remote Connectivity Analyzer (https://testconnectivity.microsoft.com), “Exchange ActiveSync” test, reports for this endpoint:
The Microsoft Connectivity Analyzer failed to obtain an Autodiscover XML response.
The Response element in the payload was null.
(It reads only a Response element in the mobilesync namespace, and there isn’t one.)
The “Outlook connectivity” test against the same endpoint gets the IMAP/POP3/SMTP settings as expected, so the Outlook path itself works.
Effect on Outlook
Microsoft’s cloud autodetect service is what new Outlook for Windows queries when adding an account:
curl -s 'https://prod.autodetect.outlook.cloud.microsoft/autodetect/detect?app=outlookdesktopBasic&services=office365,outlook,google,icloud,yahoo,imap,pop3,smtp&protocols=all&timeout=20' \
  -H 'X-Email: [email protected]'
  • Before autodiscover.<domain> had a valid certificate, the service returned {"protocol":"imap","hostname":"mail.example.com","port":993,...} (plus SMTP and POP3), and Outlook autofilled them.
  • After, for every domain on the server: {"protocols":[{"protocol":"eas","validated":false}]}. Outlook no longer autofills anything.
  1. Put autodiscover in a domain’s certificate subject alternative names, so that https://autodiscover.example.com presents a valid certificate.
  2. Send an ActiveSync Autodiscover request:
    curl -s https://autodiscover.example.com/autodiscover/autodiscover.xml \
      -H 'Content-Type: text/xml' \
      --data '<?xml version="1.0" encoding="utf-8"?>
    <Autodiscover xmlns="http://schemas.microsoft.com/exchange/autodiscover/mobilesync/requestschema/2006">
      <Request>
        <EMailAddress>[email protected]</EMailAddress>
        <AcceptableResponseSchema>http://schemas.microsoft.com/exchange/autodiscover/mobilesync/responseschema/2006</AcceptableResponseSchema>
      </Request>
    </Autodiscover>'
SQL
Client: new Outlook for Windows, Microsoft Outlook 1.2026.915.300 (client 20260918007.16, WebView2 154.0.4258.37). Account setup is driven by Microsoft’s cloud autodetect service (prod.autodetect.outlook.cloud.microsoft), not by the client probing the server itself.
Also verified with Microsoft Remote Connectivity Analyzer (testconnectivity.microsoft.com): the “Outlook connectivity” test gets the IMAP/POP3/SMTP settings from autodiscover; the “Exchange ActiveSync” test gets HTTP 200 with the same 1573-byte Outlook body and reports “The Response element in the payload was null”.
Network: Stalwart runs on Kubernetes. Port 443 is reached through HAProxy on a VPS in TCP mode with SNI routing (TLS passthrough), so Stalwart terminates TLS itself with its own ACME certificates (DNS-01). No HTTP reverse proxy rewrites the requests or responses. Four domains on the server; all show the same behaviour once autodiscover. is on the certificate.
This confirms the report is accurate: the current source explicitly ignores AcceptableResponseSchema and any other tags under Request, and always builds the Outlook-schema response regardless of what schema was requested. This is a code-level behavior, not a documented/configurable setting, so it’s a genuine bug rather than something addressable via config.
Confirmed in the source: handle_autodiscover_request in autodiscover.rs parses only the EMailAddress from the incoming request and explicitly skips/ignores AcceptableResponseSchema and any other child tags under Request (the code comment even says “Skip unsupported tags under Request, such as AcceptableResponseSchema”). The response builder then unconditionally emits the Outlook responseschema/2006a body regardless of what schema was requested, with no branching for the ActiveSync/mobilesync schema or any other. There is no configuration setting for this behavior, it’s hardcoded, so what you’re seeing (HTTP 200 with an Outlook body to every request, including ActiveSync ones) matches exactly what the code does today.
This is a legitimate gap rather than something you can work around via configuration, since Autodiscover only implements the Outlook/IMAP path. A human maintainer will need to follow up on whether/how ActiveSync-schema requests should be rejected or answered differently.
Fixed in v0.16.25 (yet to be released).
