Automatic DNS Management fails for ClouDNS
I have configured my ClouDNS provider with my auth-id and auth-password. However, all Perform DNS Management tasks fail with “Invalid authentication, incorrect user ID or password.”
The DNS Management task should update my DNS with the selected records.
Tasks fail with “Invalid authentication, incorrect user ID or password.”
Failed to create DNS record for v1-ed25519-20260528._domainkey.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for v1-rsa-20260528._domainkey.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for mail.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _dmarc.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _caldavs._tcp.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _carddavs._tcp.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _imaps._tcp.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _jmap._tcp.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _pop3s._tcp.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _submissions._tcp.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for mta-sts.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _mta-sts.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _smtp._tls.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for ua-auto-config.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for _ua-auto-config.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for autoconfig.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.; Failed to create DNS record for autodiscover.villadetara.com.: Failed to create DNS record: API error: ClouDNS add-record failed: Failed Invalid authentication, incorrect user ID or password.
From the command-line I can confirm that the auth-id and auth-password I have configured in Stalwart are indeed correct:
curl -s "https://api.cloudns.net/login/login.json?auth-id=59953&auth-password=$(cat /etc/stalwart/.cloudns-auth-password)"
{"status":"Success","statusDescription":"Success login.","session_id":"9c35f34de32421a8d5849311152e4f2c"}
If I tag my issue as ‘no-ai’ (not intentionally) but remove it, how do I get anyone to triage my submission?
That error text is ClouDNS’s own response passed straight through; Stalwart authenticates with exactly the auth-id/auth-password (or sub-auth-id) you configured. The catch is that a working login/login.json call only proves the credential is a valid login, not that it has DNS API access, which ClouDNS controls separately.
Two common causes: the credential is an API sub-user (it has to go in the sub-auth-id field, not auth-id), or the API IP allow-list doesn’t include your server. Test the DNS API directly, e.g. curl “https://api.cloudns.net/dns/get-zone-info.json?auth-id=...&auth-password=…”; if that also fails, the credential lacks DNS API permission and Stalwart will fail the same way.
Clearly you and everyone else (including me) hit fix(cloudns): correct Content-Type on writes; surface ClouDNS API errors on list - Pull Request #73 - stalwartlabs/dns-update - GitHub
