Environment:
Ubuntu 24.04 (fresh installation)
Official Docker CE
Official image: Package stalwart · GitHub
Docker named volumes
No reverse proxy
No HTTPS
No DNS configuration
No custom environment variables
Compose file:
services:
stalwart:
container_name: stalwart
ports:
- “8080:8080”
volumes:
- etc:/etc/stalwart
- data:/var/lib/stalwart
volumes:
etc:
data:
After completing the setup wizard successfully, Stalwart should restart and start in normal mode instead of bootstrap mode.
The setup wizard finishes successfully and displays “Setup complete”.
After restarting the container, Stalwart enters bootstrap mode again.
The logs always contain:
Server started in bootstrap mode
No configuration file was found. Port 8080 is open for initial setup.
The temporary bootstrap administrator is generated again.
Start a fresh container.
Open http://SERVER_IP:8080/admin
Sign in using the temporary bootstrap credentials.
Complete the setup wizard.
Wait until “Setup complete” is displayed.
Restart the container.
Stalwart starts in bootstrap mode again.
2026-07-02T09:26:46Z WARN Server started in bootstrap mode (server.bootstrap-mode) hostname = “b400eae54602”, details = “No configuration file was found. Port 8080 is open for initial setup.”, version = “0.16.11”
2026-07-02T09:28:28Z INFO Authentication successful (auth.success) accountName = “admin”
2026-07-02T09:30:00Z INFO Shutting down Stalwart Server (server.shutdown) causedBy = “SIGTERM”
