When deleting an event from the Bulwark web interface, the event is not removed from Apple Calendar on macOS after CalDAV synchronization.
However, deletion synchronization (and deletion) works correctly with Android calendar clients.
The event should be removed from Apple Calendar after it is deleted in Bulwark.
The event remains visible in Apple Calendar even after it has been deleted from the Bulwark web interface.
- Open the Bulwark calendar web interface.
- Create an event and wait for synchronization with Apple Calendar.
- Delete the event from the Bulwark web interface.
- Wait for synchronization to complete.
- Open Apple Calendar on macOS.
Meilisearch
OIDC
Environment
- Bulwark version: 1.7.3
- Stalwart Mail Server version: 0.16.7
- macOS: 26.5
- Calendar client: Apple Calendar
- Synchronization protocol: CalDAV
- Firefox: 151.0.2
Additional Information
- Event creation is synchronized correctly between Bulwark and Apple Calendar.
- Events deleted from the Bulwark web interface remain present in Apple Calendar.
- Events deleted from Apple Calendar is correctly erased in Bulwark web interface.
- Deletion synchronization works correctly on Android calendar clients.
- Synchronization itself appears to be functioning correctly apart from event deletion on macOS.
