Stalwart allow setting invalid caldav color values and subsequently does not behave normally any more regarding this property.
I think stalwart should reject invalid properties that it uses internally.
The invalid value is accepted and can later on not be changed in standard ways.
When creating a calendar via caldav with an invalid color property value (please don’t ask) like this
<?xml version="1.0" encoding="utf-8"?>
<D:mkcol xmlns:D="DAV:" xmlns:C="urn:ietf:params:xml:ns:caldav">
<D:set>
<D:prop>
<D:resourcetype>
<D:collection/>
<C:calendar/>
</D:resourcetype>
<calendar-color xmlns="http://apple.com/ns/ical/">#</calendar-color>
</D:prop>
</D:set>
</D:mkcol>
Stalwart actually stores this information somehow, and it will be reported back as is for PROPFIND.
Internally, however, the color is not set (empty input field in the ui). It is subsequently possible to change the color in the stalwart ui (which also propagates via jmap, I suppose), but not for caldav, which will still show the invalid value. Additionally, it is not impossible to set the color via carddav PROPPATCH
<d:propertyupdate xmlns:d="DAV:">
<d:set>
<d:prop>
<calendar-color xmlns="http://apple.com/ns/ical/">#0000ff</calendar-color>
</d:prop>
</d:set>
</d:propertyupdate>
Only after removing the property altogether via PROPPATCH
<d:remove>
<d:prop>
<calendar-color xmlns="http://apple.com/ns/ical/"/>
</d:prop>
</d:remove>
</d:propertyupdate>
It starts behaving correctly again.
