CalendarEvent/get omits recurrenceRule and recurrenceOverrides for synthetic instances instead of returning null
When CalendarEvent/get returns a server-expanded synthetic recurrence instance, explicitly requested recurrenceRule and recurrenceOverrides properties are omitted.
The JMAP Calendars draft requires these properties to:
“MUST be returned as null if requested for such an event.”
For a synthetic recurrence instance, explicitly requested recurrenceRule and recurrenceOverrides properties should both be present with a value of null.
Stalwart omits the requested properties entirely from the returned CalendarEvent.
  1. Create a recurring CalendarEvent.
  2. Obtain a synthetic occurrence id using CalendarEvent/query with expandRecurrences: true.
  3. Fetch that id using CalendarEvent/get and explicitly request id, recurrenceRule, and recurrenceOverrides.
  4. Observe that recurrenceRule and recurrenceOverrides are absent rather than null.
N/A
Built from source
This is a code-level bug report rather than a docs/config question, so I’ll note that a human maintainer will need to confirm and address it directly in the source.
try harder, @helpbot :joy:
Fixed in v0.16.22 (yet to be released).
