Cannot set defaultCertificateId using stalwart-cli plan
When trying to apply a plan using stalwart-cli, I get the following error message:
error: SystemSettings: update failed for id singleton: error: invalidPatch | Failed to parse Id from string | Properties: defaultCertificateId
defaultCertificateId should apply without issues.
stalwart-cli fails with error: SystemSettings: update failed for id singleton: error: invalidPatch | Failed to parse Id from string | Properties: defaultCertificateId
  1. Use stalwart-cli v1.0.10 and stalwart v0.16.13
  2. Attempt to apply following plan while stalwart is in recovery mode:
{"@type":"upsert","matchOn":["subjectAlternativeNames"],"object":"Certificate","value":{"certificate-i2evq3oqabaa":{"certificate":{"@type":"File","filePath":"/var/lib/acme/david-w.eu/fullchain.pem"},"privateKey":{"@type":"File","filePath":"/var/lib/acme/david-w.eu/key.pem"},"subjectAlternativeNames":{"*.david-w.eu":true,"david-w.eu":true}}}}
{"@type":"reconcile","matchOn":["key"],"object":"DnsServer","value":{"dnsserver-1":{"@type":"Tsig","description":"Knot DNS","host":"::1","key":{"@type":"File","filePath":"/run/credentials/stalwart.service/tsig-key"},"keyName":"stalwart","port":53,"protocol":"udp","tsigAlgorithm":"hmac-sha512"}}}
{"@type":"reconcile","matchOn":["name"],"object":"Domain","value":{"domain-1":{"certificateManagement":{"@type":"Manual"},"description":"Default","dkimManagement":{"@type":"Automatic"},"dnsManagement":{"@type":"Automatic","dnsServerId":"#dnsserver-1"},"name":"david-w.eu"}}}
{"@type":"reconcile","matchOn":["name"],"object":"NetworkListener","value":{"listener-1":{"bind":{"[::1]:8087":true},"name":"https","protocol":"http","tlsImplicit":true,"useTls":true},"listener-2":{"bind":{"[::]:25":true},"name":"smtp","protocol":"smtp","useTls":true},"listener-3":{"bind":{"[::]:465":true},"name":"smtps","protocol":"smtp","tlsImplicit":true,"useTls":true},"listener-4":{"bind":{"[::]:993":true},"name":"imaps","protocol":"imap","tlsImplicit":true,"useTls":true},"listener-5":{"bind":{"[::]:4190":true},"name":"sieve","protocol":"manageSieve","tlsImplicit":true,"useTls":true}}}
{"@type":"reconcile","matchOn":["name"],"object":"Account","value":{"account-1":{"@type":"User","credentials":{"0":{"@type":"Password","secret":"****"}},"description":"David Wronek","domainId":"#domain-1","name":"moe","roles":{"@type":"Admin"}}}}
{"@type":"update","object":"SystemSettings","value":{"defaultCertificateId":"#certificate-i2evq3oqabaa","defaultDomainId":"#domain-1","defaultHostname":"mail.david-w.eu"}}
{"@type":"update","object":"Http","value":{"enableHsts":true,"useXForwarded":true}}
Plan: 0 destroy, 2 update, 0 create, 1 upsert, 4 reconcile (9 objects)
✓ upserted Certificate (1)
✓ reconciled DnsServer (1)
✓ reconciled Domain (1)
✓ reconciled NetworkListener (5)
✓ reconciled Account (1)
✗ update SystemSettings: SystemSettings: update failed for id singleton: error: invalidPatch |   Failed to parse Id from string |   Properties: defaultCertificateId
Done: 0 destroyed, 8 updated, 1 created (1 failed)
NixOS
Please add information whether or not --rawfield is being used.
Reason for that request: Cannot update certificate via stalwart-cli - #4 by jeremiahcfoster
Hi stappers,
thanks for your reply.
I don’t use `–rawfile`. The command I use is the following:
`stalwart-cli apply --file stalwart-plan.ndjson`
Best regards
David
Acknowledge.
I zoomed in on the last two lines of stalwart-plan.ndjson
stappers@messer:/dev/shm/temp
$ cat the_update_lines
{"@type":"update","object":"Http","value":{"enableHsts":true,"useXForwarded":true}}#
$ cat the_update_lines | jq
  "@type": "update",
  "object": "SystemSettings",
  "value": {
    "defaultCertificateId": "#certificate-i2evq3oqabaa",
    "defaultDomainId": "#domain-1",
    "defaultHostname": "mail.david-w.eu"
  "@type": "update",
  "object": "Http",
  "value": {
    "enableHsts": true,
    "useXForwarded": true
jq: parse error: Invalid numeric literal at line 2, column 85
$ $EDITOR the_update_lines
  "@type": "update",
  "value": {
  "@type": "update",
  "object": "Http",
  "value": {
    "enableHsts": true,
My prime suspect is the # in "defaultDomainId": "#domain-1",
My bad, there has been an issue while I pasted in the NDJSON plan.
I have fixed it now.
Regardless if I use the # character to reference to domain ID/certificate ID or not, I’m still getting the Failed to parse Id from string error message.
I did read that as further ideas are welcome.
Do apply with just this as file content:
  "@type": "update",
  "value": {
Once again to understand update
  "@type": "update",
  "value": {
Extend
  "@type": "update",
  "value": {
And the original request:
  "@type": "update",
  "value": {
Try with --rawfile , that helped me.
