Catchall ignored for local bounces
When a message bounces during the outbound SMTP connection, the returned message is discarded if the recipient is not found (VERP), even if there is a catchall set for the sending domain.
If there is a catchall set, it should be honoured on both regular and bounce paths.
There are two separate recipient-resolution paths and only one of them honors catch-all.
Inbound SMTP RCPT path — crates/common/src/network/mta.rs, rcpt_resolve(). Catch-all is applied unconditionally for an unresolved recipient:
rust// Catch-all resolution
if let Some(catch_all) = &domain.catch_all {
return Ok(RcptResolution::Rewrite(catch_all.to_string()));
The RCPT handler (crates/smtp/src/inbound/rcpt.rs) then rewrites the envelope recipient to the catch-all address before the message is queued. That’s why ordinary inbound mail to unknown recipients works.
Local delivery path — crates/email/src/message/delivery.rs:122:
rustlet account_id = match self.account_id_from_email(&rcpt.address, false).await {
Ok(Some(account_id)) => account_id,
Ok(None) => {
result.status.push(LocalDeliveryStatus::PermanentFailure {
code: [5, 5, 0], reason: “Mailbox not found.”.into(),
continue;
Any mailing list software operating behind Stalwart would use VERP, I am using mlmmj. Reproducible by sending a message with MAIL FROM set to a VERP address.
queueId = 308881299387452928, queueName = “local”, from = “<>”, to = [“test-94q8e5k+bounces-9-{REMOVED}”], size = 3300, total = 1, to = [“<test-94q8e5k+bounces-9-{REMOVED} (host ‘localhost’ rejected command ‘RCPT TO:<test-94q8e5k+bounces-9-{REMOVED}>’ with code 550 (5.5.0) ‘Mailbox not found.’)\r\n”]
The report is accurate and well-researched. Here’s a confirmation of what the code shows:
The user has correctly identified a genuine bug. In crates/common/src/cache/principals.rs, account_id_from_email() takes a resolve boolean parameter that gates catch-all (and sub-addressing) lookup:
pub async fn account_id_from_email(
    &self,
    address: &str,
    resolve: bool,       // <-- controls catch-all
) -> trc::Result<Option<u32>> {
    if resolve && result.is_none() && let Some(catch_all) = &domain.catch_all {
        result = self.rcpt_id_from_email(catch_all).await?;
In crates/email/src/message/delivery.rs line 122, the local delivery path calls this with false:
…which skips catch-all resolution entirely. The inbound SMTP RCPT path (rcpt.rs) uses a different code path (rcpt_resolve() in mta.rs) that does apply catch-all before the message is even queued, so inbound mail works correctly. But bounce messages delivered locally (e.g. VERP returns from a mailing list) bypass that SMTP RCPT path and go directly to local delivery, where resolve: false means catch-all is never consulted.
This is a confirmed code-level bug: the fix would be to pass true instead of false in the local delivery call to account_id_from_email, so that catch-all resolution is applied consistently on the local delivery path. This is not a configuration issue; there is no workaround available through Stalwart’s settings.
A human/developer will need to address this in the codebase.
This will be fixed in v0.16.7.
