Can Vandelay be used to copy multiple/all accounts on an Stalwart server?
Vandelay is designed to copy one account at a time – the documented procedure runs the import/export cycle per account and repeats it for each one. There is no built-in “copy all accounts at once” flag in Vandelay itself. However, you can script the process: loop over your list of account identifiers, running vandelay import and vandelay export for each one. Because both halves are convergent (interrupted or repeated runs simply resume from where they left off), you can safely automate the loop.
The overall workflow is:
vandelay import <source-protocol> ... <account>.sqlite for each account.vandelay inspect <account>.sqlite if desired.vandelay export ... <account>.sqlite to push it onto the new server.Full step-by-step details, including the exact commands for JMAP, IMAP, CalDAV, and WebDAV sources, are in the Migrating accounts guide and the Migration overview.
