account/Settings/x:DmarcReportSettings exposes Subject: Subject name that will be used in the DMARC aggregate report email, default 'DMARC Aggregate Report'.
However, the Stalwart docs reference “The subject of an aggregate report is not configurable. RFC 9990, section 3.5.2 requires a fixed format, Report Domain: Submitter: Report-ID: <>. In it, is the domain the report is about and is the outboundReportSubmitter host name.” Indeed, this fixed format is what is used for outgoing emails.
If the subject is not configurable, the setting should be removed.
The current docs already match what you expected. In v1.0, DmarcReportSettings has no aggregate subject field. Its aggregate fields are aggregateFromAddress, aggregateFromName, aggregateOrgName, aggregateContactInfo, maxAggregateReportSize, aggregateSendFrequency and aggregateDkimSignDomain. The only subject setting left is failureSubject, which applies to DMARC failure reports, not aggregate ones. See DmarcReportSettings.
The source agrees with the docs. The aggregate report generator in smtp-report uses Report Domain: <domain> Submitter: <submitter> Report-ID: <<report_id>> as the default subject, as the DMARC reports page describes.
You reported v0.16.x, where the setting is still exposed. Treat it as having no effect on aggregate reports, since the fixed format is what you saw in outgoing mail. This answer is based on the v1.0 docs and source, so I can’t say how v0.16 behaves internally. Upgrading should get you the schema without the field. The upgrade guide is here: Overview | Stalwart
