DMARC is skipped when MAIL FROM SPF is unavailable
Stalwart skips DMARC verification when no MAIL FROM SPF result is available.
This means a message with an aligned, passing DKIM signature cannot pass DMARC if MAIL FROM SPF is disabled, unavailable, or the message uses a null reverse path.
Seen with Google SMTP TLS reports from noreply-smtp-tls-reporting [at] google [dot] com. They used a null MAIL FROM and had an aligned DKIM signature for google [dot] com, but Stalwart skipped DMARC because SPF was NA.
Fix and test:
The fix passes an SPF none result into DMARC verification. It does not create an SPF pass.
Please let me know if this bug fix be acceptable.
DMARC should still evaluate DKIM alignment. Missing SPF should count as no SPF pass, not skip DMARC entirely.
DKIM passes, but no DMARC result or policy is produced.
  1. Disable MAIL FROM SPF verification or send with MAIL FROM:<>.
  2. Send a DKIM-signed message whose From domain is aligned.
  3. Check the authentication results.
DKIM: pass
SPF: NA
DMARC: no result
LDAP
Fixed in v0.16.14 (not yet released).
