Documentation mismatch: PACC endpoint returns 404/error without .json extension
There appears to be a discrepancy between the official documentation and the actual live behavior of the server regarding the PACC (Automatic Configuration of Email, Calendar, and Contact Server Settings) endpoint.
According to the Autoconfig | Stalwart documentation page:
“…a PACC-aware client uses the domain part of the address to fetch the configuration from the well-known URI defined by RFC 8615, using the suffix user-agent-configuration… retrieves https://example.com/.well-known/user-agent-configuration and parses the JSON response.”
However, during live API testing, the behavior is as follows:
Calling GET /.well-known/user-agent-configuration results in an error / 404 Not Found.
Calling GET /.well-known/user-agent-configuration.json successfully returns the expected JSON configuration.
Let me look into the PACC endpoint behavior in both the docs and server source.
This is a confirmed documentation bug. The server source code shows the route is registered exclusively as "user-agent-configuration.json" – the .json extension is required. However, the documentation (and the IETF draft it references) describes the path without the extension as /.well-known/user-agent-configuration.
What the server actually does: The HTTP request handler matches only user-agent-configuration.json (confirmed in server/crates/http/src/request.rs, line 308). Requesting /.well-known/user-agent-configuration (without .json) returns a 404 because no route exists for that path.
What the docs say: The Autoconfig documentation states the client retrieves https://example.com/.well-known/user-agent-configuration – without any .json extension – which matches what the underlying IETF draft (draft-ietf-mailmaint-pacc-02) specifies.
So there is a genuine mismatch: either the server should also accept the extension-less path (per the IETF draft/RFC 8615 convention), or the docs need to clarify that Stalwart’s implementation requires .json. Either way, one of them needs to be corrected. A human will follow up on which is the intended behavior.
The documentation will be fixed shortly, thanks for the report.
