I have a very small deployment and I’m considering the best way to switch to 0.16.
I’m thinking of building a fresh deployment and then using Vandelay to export/import the data, as the total size is under 1 GB. Would this be the recommended approach?
I can always reset the users’ credentials, so that would not be an issue.
Thank you!
Your instinct to do a fresh install and migrate the data is actually the approach the official docs recommend for the 0.16 upgrade. Here’s the picture:
The built-in --export / --import CLI flags are the right tool for this. The Stalwart binary has a built-in Database Import/Export utility designed exactly for this scenario. It creates a binary dump of the entire internal database that can be loaded into a fresh instance. “Vandelay” is the name for this same built-in tool.
The key steps from the docs:
Stop the old server before exporting – this is required; running an export against a live embedded backend (RocksDB/SQLite) risks corruption.
Important caveat for 0.16 specifically: The blog post for 0.16 flags it as a major upgrade with multiple breaking changes and strongly recommends reading the v0.16 upgrading documentation in full before proceeding, as the architectural changes are significant. The export/import approach works for moving between storage backends, but the 0.16 upgrade notes may have additional steps on top of that.
Since your data is under 1 GB, a fresh install + import is a perfectly reasonable path. Just be sure to follow the v0.16 upgrade guide alongside it.
I don’t really care about the configuration. On the contrary, I believe that starting fresh (totally new config) is best as I made the initial install on a hurry.
So I just need to import mailbox contents. I can recreate everything from scratch, including new account creation.
