I’m planning a migration from an existing IMAP setup, and I’m trying to minimise user disruption by keeping their existing usernames and passwords. All the usernames are fine as they’re [email protected] which fits in with Stalwart’s schema, but the passwords are hashed. Is it possible to set the password with this pre-hashed value?
The passwords doc says that Stalwart recognises a number of different formats, but can the password be set in one of those formats directly?
I’ve tried running:
stalwart-cli update account c --field credentials/0/secret='$1$test$2uZnGZGO4rM51ZnqzUT7f/' -k
but then the password gets set to exactly that value. Similarly with prepending {CRYPT} to the hash.
I can see that an external directory might work, but I’d prefer to use a “vanilla” Stalwart setup without this complication. It is a small personal setup.
Also let’s check how hash_secret is called when setting credentials via CLI to understand the issue:
Based on a careful look at the source code, here is what is actually happening and what your options are:
The short answer: the admin principal API always re-hashes whatever you write into credentials/0/secret. Looking at crates/jmap/src/registry/mapping/principal.rs (line 300) and the bootstrap code, every time a credential secret is written via the admin path, hash_secret() is called on the raw value before it is stored. That is why your MD5-crypt hash is being stored as a literal string — it gets hashed again (as if it were a plaintext password), rather than being recognised as an already-hashed value.
However, looking at crates/directory/src/core/secret.rs, the verification side (verify_secret_hash) does correctly detect and handle a large number of hash prefixes at login time:
The problem is that the admin write path calls hash_secret() unconditionally, so there is currently no supported way to bypass hashing and inject a pre-existing hash string via stalwart-cli or the admin API for internal-directory accounts.
Your realistic options for migration:
Force a password reset for all users — migrate accounts with a temporary random password and have users reset on first login.
Use an external SQL or LDAP directory temporarily during migration, where the columnSecret / attrSecret is read directly (not re-hashed), and migrate users across gradually.
Open a feature request on the Stalwart GitHub asking for an “import pre-hashed password” flag in the admin API — the verification code already supports all the formats, the gap is only on the write path.
This isn’t documented as a known limitation in the current docs, so a community member or staff member may be able to confirm whether a workaround exists that isn’t covered here.
@svenihoney Stalwart only accepts hashed passwords in bootstrap or recovery mode. Otherwise you need to set passwords in clear text over a TLS connection which are then encrypted by Stalwart.
@patch Only if you use an external directory. Otherwise it is stores serialized inside the account object.
stalwart-cli apply migrated my passwords flawlessly. After the migration the unpatched executable took over. Would be nice if this codeblock could be made optional e.g. by an option in config.json.
