We created calendar events from one internal account to another internal account using JMAP Calendars. The organizer account had a valid default ParticipantIdentity,
global scheduling was enabled, and we explicitly tested several event payload variants, including:
- a normal event with attendees
- an event with attendee sendTo.imip
- an event with sendSchedulingMessages: true
- an event with both sendSchedulingMessages: true and explicit replyTo.imip
In every case, the event was created successfully in the organizer’s calendar, but no invitation was generated or delivered:
- no CalendarEvent appeared in the invitee account
- no CalendarEventNotification appeared in the invitee account
- no email invitation appeared in the invitee mailboxes
- no background CalendarItipMessage task appeared in the task queue
- no outbound queued message appeared
This does not look like a simple autoAddInvitations issue, because even when automatic calendar insertion is disabled, we would still expect scheduling/invitation
processing to happen when explicitly requested.
Expected behavior:
When an event is created via CalendarEvent/set with attendees and sendSchedulingMessages: true, Stalwart should generate the appropriate scheduling workflow for
those attendees. -
For an internal attendee, this should result in either:
a scheduling notification/invitation being available to the recipient account, or
delivery through the supported scheduling path configured by Stalwart.
At minimum, we would expect server-side evidence that scheduling was triggered, such as a CalendarItipMessage task or an outbound queued message if iMIP is used.
Relevant docs/spec references:
- Stalwart Scheduling docs: Scheduling | Stalwart
- Stalwart CalendarScheduling object: CalendarScheduling | Stalwart
- JMAP Calendars spec: https://jmap.io/spec-calendars.html
The JMAP Calendars spec says CalendarEvent/set supports sendSchedulingMessages, and when this is true, the server must send the appropriate scheduling messages.
Actual behavior:
- CalendarEvent/set succeeds and stores the event in the organizer’s calendar.
- The attendee remains only as a participant on the organizer-side object.
- Nothing is created or delivered on the recipient side.
Specifically:
- recipient CalendarEvent/query returns no events
- recipient CalendarEventNotification/query returns no notifications
- recipient Email/query shows no invitation email
- admin x:Task/query shows no CalendarItipMessage
- admin x:QueuedMessage/query shows no outbound queued invitation message
So the deviation is that scheduling appears not to start at all, even when explicitly requested.
Ensure Stalwart JMAP is reachable and calendars are enabled.
Verify admin configuration:
- x:CalendarScheduling/get returns:
- enable: true
- httpRsvpEnable: true
- autoAddInvitations: false
Verify the organizer account has a default participant identity:
- ParticipantIdentity/get returns a default identity such as mailto:[email protected]
Create an event from organizer to invitee using CalendarEvent/set with:
- organizer participant
- internal attendee participant
- sendTo.imip on the attendee
- sendSchedulingMessages: true
Observe that the event is created successfully in the organizer account.
Query the invitee account:
- CalendarEvent/query
- CalendarEventNotification/query
- Email/query
Query admin endpoints:
- x:Task/query
- x:QueuedMessage/query
Observe that no scheduling artifact is produced anywhere.
Example JMAP request used for reproduction:
"using": [
"urn:ietf:params:jmap:core",
"urn:ietf:params:jmap:calendars"
"methodCalls": [
"CalendarEvent/set",
"accountId": "ORGANIZER_ACCOUNT_ID",
"sendSchedulingMessages": true,
"create": {
"test1": {
"@type": "Event",
"title": "Scheduling reproduction test",
"description": "<p>Test event</p>",
"start": "2026-06-07T12:00:00",
"duration": "PT30M",
"timeZone": "Africa/Djibouti",
"showWithoutTime": false,
"status": "confirmed",
"freeBusyStatus": "busy",
"privacy": "public",
"calendarIds": {
"DEFAULT_CALENDAR_ID": true
"participants": {
"p1": {
"@type": "Participant",
"calendarAddress": "mailto:[email protected]",
"name": "User One",
"roles": {
"owner": true,
"attendee": true
"participationStatus": "accepted",
"expectReply": false,
"kind": "individual"
"p2": {
"name": "User Two",
"roles": {
"attendee": true
"participationStatus": "needs-action",
"expectReply": true,
"kind": "individual",
"sendTo": {
"imip": "mailto:[email protected]"
"c1"
Observed response:
"methodResponses": [
"newState": "…",
"created": {
"test1": {
"id": "EVENT_ID"
"c1"
"sessionState": "…"
Then:
- invitee CalendarEvent/query returns ids:
- invitee CalendarEventNotification/query returns ids:
- invitee Email/query shows no invitation
- admin x:QueuedMessage/query returns ids:
- admin x:Task/query does not contain any CalendarItipMessage
No relevant logs were collected yet.
What we did verify through JMAP:
x:CalendarScheduling/get:
- enable = true
- httpRsvpEnable = true
- autoAddInvitations = false
ParticipantIdentity/get on organizer:
- default participant identity exists
Recipient-side checks after event creation:
- CalendarEvent/query =>
- CalendarEventNotification/query =>
- Email/query => no invitation message found
Admin-side checks:
- x:Task/query => no CalendarItipMessage task
- x:QueuedMessage/query => no queued outbound message
Meilisearch
