JMAP: HTTP 400 "notRequest" when a method invocation name contains a JSON-escaped solidus ("\/")
Stalwart returns urn:ietf:params:jmap:error:notRequest (HTTP 400) for an otherwise-valid JMAP request whenever the method invocation name — the first element of a methodCalls triple — contains a JSON-escaped forward slash (\/) instead of a literal /.
Per RFC 8259 §7, \/ is an explicitly permitted escape for the solidus (U+002F). A JSON parser must treat "Core\/echo" and "Core/echo" as the identical string Core/echo. Stalwart accepts \/ inside JSON values but rejects it in a method name, which indicates the method name is being matched before (or without) applying JSON string unescaping to that token.
"Core\/echo" and "Core/echo" are the same JSON string per RFC 8259 §7, so the escaped form should behave identically to the unescaped one: HTTP 200 with the echoed response.
The request is rejected with HTTP 400 urn:ietf:params:jmap:error:notRequest, treating the entire otherwise-valid request as malformed. The same \/ escape inside an argument value decodes correctly — only the method-name token is matched without unescaping.
Core/echo is a safe no-op. The three requests differ by exactly one character; credential redacted as USER:PASS.
  1. Literal / in the method name → 200 OK:
    curl -s -u ‘USER:PASS’ -H ‘Content-Type: application/json’ https://HOST/jmap/ --data-binary ‘{“using”:[“urn:ietf:params:jmap:core”],“methodCalls”:[[“Core/echo”,{“hello”:“world”},“c1”]]}’
    → {“methodResponses”:[[“Core/echo”,{“hello”:“world”},“c1”]],…}
  2. JSON-escaped \/ in the method NAME → 400 notRequest (the bug):
    …methodCalls":[[“Core/echo”,{“hello”:“world”},“c1”]]}’
    → HTTP 400 {“type”:“urn:ietf:params:jmap:error:notRequest”,“status”:400,…}
  3. JSON-escaped \/ in an argument VALUE → 200 OK (decoded fine):
    …methodCalls":[[“Core/echo”,{“path”:“a/b”},“c1”]]}’
    → {“methodResponses”:[[“Core/echo”,{“path”:“a/b”},“c1”]],…} (the / became /)
Real-world impact: Apple’s Foundation JSONSerialization always escapes / as \/ with no opt-out, so any JMAP client built on it (a great deal of Swift/Objective-C code) is rejected on every request, while JSONEncoder / Python json.dumps / Go encoding/json are unaffected — which makes this confusing to diagnose across clients.
This is a confirmed parsing bug, and the root cause is visible in the source: the method-name token in a JMAP call is deserialized directly as a borrowed &str:
let method_name = seq
    .next_element::<&str>()?
    .ok_or_else(|| de::Error::invalid_length(0, &self))?;
let name = match MethodName::parse(method_name) {
(crates/jmap-proto/src/request/parser.rs)
serde_json can only produce a zero-copy &str when the JSON string contains no escape sequences; the moment the method name contains \/ (or any other escape), it can’t borrow it and the whole deserialization step fails, which bubbles up as serde_json::Error and gets wrapped into urn:ietf:params:jmap:error:notRequest. Argument values elsewhere in the request are deserialized into owned String/structs, so escapes there are unescaped normally, matching what you observed.
This is a genuine spec-compliance gap (RFC 8259 §7 requires \/ and literal / to be treated identically), not expected behavior, and it’s not something documented as a limitation. I don’t have a way to file this for you, but a staff or community member monitoring this category should pick it up from your detailed repro.
