I am trying to configure an LDAP directory with bindAuthentication: true through the JMAP Directory/set API.
The LDAP provider exposes the password-change timestamp as pwdChangedTime. Stalwart documents attrSecretChanged as the LDAP directory field used to configure which LDAP attribute should be used as the password-change marker for token invalidation.
However, when creating the LDAP directory through JMAP Directory/set, Stalwart rejects attrSecretChanged with invalidPatch.
This appears to be a mismatch between the documented LDAP Directory configuration and the JMAP Directory/set validation/schema
The following LDAP Directory payload should be accepted:
“@type”: “Ldap”,
“url”: “ldap://ldap.example.internal:389”,
“baseDn”: “dc=example,dc=internal”,
“bindDn”: “cn=ldap-service,ou=users,dc=example,dc=internal”,
“bindAuthentication”: true,
“attrSecretChanged”: [“pwdChangedTime”],
“filterLogin”: “(&(objectClass=person)(mail=?))”,
“filterMailbox”: “(&(objectClass=person)(mail=?))”
Expected behavior: Stalwart should persist the LDAP directory and use pwdChangedTime as the password-change marker for LDAP bind authentication.
Relevant documentation: the LDAP Directory object documents attrSecretChanged as the configurable password-change marker attribute, with default [“pwdChangeTime”].
JMAP Directory/set rejects the payload with:
“methodResponses”: [
“x:Directory/set”,
“accountId”: “d333333”,
“notCreated”: {
“new1”: {
“type”: “invalidPatch”,
“description”: “Invalid value for object property”,
“properties”: [“attrSecretChanged”]
“c1”
The deviation is that attrSecretChanged is documented as a valid LDAP Directory field, but the JMAP API rejects it during directory creation.
- Run Stalwart v0.16.7.
- Use an LDAP provider that exposes a password-change timestamp attribute named pwdChangedTime.
- Create an LDAP directory through JMAP Directory/set.
Include the field:
Submit the request. - Observe that the directory is not created and JMAP returns invalidPatch for attrSecretChanged.
Waiting for Stalwart JMAP at https://stalwart.example.internal:443/jmap … API ready (HTTP 200) [auth-ldap] reconciling LDAP directory for ldap://ldap.example.internal:389 baseDn=dc=example,dc=internal … [auth-ldap] creating LDAP directory … {“methodResponses”:[[“x:Directory/set”,{“accountId”:“d333333”,“notCreated”:{“new1”:{“type”:“invalidPatch”,“description”:“Invalid value for object property”,“properties”:[“attrSecretChanged”]}}},“c1”]],“sessionState”:“ca2c46e8”} [auth-ldap] LDAP directory creation failed
LDAP
The LDAP backend is an Authentik LDAP outpost. With LDAP bind authentication, Stalwart cannot read the user password hash. Therefore it needs a password-change marker attribute to invalidate OAuth/WebUI tokens after password changes.
Stalwart’s documented default is pwdChangeTime, but Authentik LDAP outpost emits the password-change timestamp as pwdChangedTime. This should be configurable through attrSecretChanged.
Currently, since JMAP rejects attrSecretChanged, the only workaround is to make the LDAP provider emit a compatibility alias named pwdChangeTime. It would be cleaner if Stalwart accepted the documented attrSecretChanged field through JMAP Directory/set.
