Management API panics (unreachable!) when changing an existing account's @type (User ↔ Group)
Changing the Account type of an existing principal from User to Group (or vice versa) — via the web-admin, the management JMAP API, or stalwart-cli — panics a worker thread and the connection is dropped without an HTTP response. The server process itself keeps running (only the request task dies).
A client request must never panic a worker thread or drop the connection — validate_account should return a result instead of hitting unreachable!(). Concretely, one of:
If account types are intentionally immutable (which the current match arms imply): the API should reject the update with a clean JMAP SetError — e.g. notUpdated with type invalidProperties on @type and a message like “the account type cannot be changed after creation”. The web-admin should then display that message instead of NetworkError when attempting to fetch resource, and ideally disable/hide the Account type selector when editing an existing account (it’s only meaningful at creation).
If converting an account’s type is meant to be supported: implement the missing match arms in validate_account so a User → Group (and Group → User) transition is handled — retaining the existing mailbox/data and adjusting the type-specific fields (credentials, roles, members) accordingly.
In both cases the _ => unreachable!() arm should be replaced with a proper, non-panicking error path, so malformed or unsupported updates are reported to the client rather than terminating the connection.
Panic
thread ‘tokio-rt-worker’ panicked at crates/jmap/src/registry/mapping/principal.rs:248:14:
internal error: entered unreachable code
Web-admin: pick a User account (empty mailbox is fine) → Edit → Account type → Group account → Save → NetworkError when attempting to fetch resource.
Equivalent management API call:
“using”: [“urn:ietf:params:jmap:core”, “urn:stalwart:jmap”],
“methodCalls”: [
[“Account/set”, { “accountId”: “”, “update”: { “”: { “@type”: “Group” } } }, “c0”]
→ worker panics (above), connection dropped, no methodResponses.
Also via stalwart-cli … account update --field @type=Group.
docker logs stalwart --since 2m 2>&1
thread ‘tokio-rt-worker’ (7) panicked at crates/jmap/src/registry/mapping/principal.rs:248:14:
Good bug report. Let me look at the relevant source code to understand and confirm what’s happening.
This confirms the bug exactly as reported. The match in validate_account only handles four arms:
  1. (Account::User(_), AccountUpdate::Update(Account::User(_))) - User updating a User
  2. (Account::Group(_), AccountUpdate::Update(Account::Group(_))) - Group updating a Group
  3. (Account::User(_), AccountUpdate::Create(_)) - Creating a User
  4. (Account::Group(_), AccountUpdate::Create(_)) - Creating a Group
Any cross-type update (e.g. User → Group or Group → User) falls through to _ => unreachable!(), which panics the worker thread. This is a confirmed bug in the source at crates/jmap/src/registry/mapping/principal.rs:248.
This is a confirmed server-side bug. When a Account/set update changes @type across principal types (User to Group or vice versa), the validate_account function hits a _ => unreachable!() arm with no error handling, causing the worker thread to panic and the connection to be dropped with no response.
The fix needs to happen in crates/jmap/src/registry/mapping/principal.rs - the _ => unreachable!() arm (line 248) must be replaced with a proper return Ok(Err(...)) that surfaces a SetError to the client (e.g. invalidProperties on @type), rather than panicking. Until then, the workaround is to never change @type on an existing account - delete and recreate it instead.
The web-admin UI also contributes to this: the Account type selector should ideally be disabled/hidden when editing an existing account (since it has no valid update path), to prevent users from hitting this panic.
A human maintainer will need to action the fix in the server source.
Fixed in v0.16.12 (to be released).
