Manual task execution and testing
The following will be extremely helpful and should be easy to implement:
  1. Please add a “Request” and “Dry-run” buttons to TLS / ACME page in order to test and perform getting of TLS certificates. The functionality is obviously written already, but without a way to trigger it, it remains a headache. There is nothing in the logs and restarting stalwart or changing the timeout in order to force a request is not practical.
  2. The same goes for adding a “Rollover” button on auto DKIM. For some reason GMail does not accept outgoing messages stating a DKIM error, but I have no way of getting a new DKIM key other than manipulating rollover periods and hoping something would appear in the logs. Being able to manually do this, would be very helpful.
  3. A “Push” ("or “Apply”) button on auto DNS page to push DNS records to the DNS provider, would also be greatly appreciated. If you want to test if DNS records are successfully applied to the DNS server, then being able to forcefully do so and verify the DNS records immediately afterwards is a better approach than to hope it would happen at some time and continually check to see if there are something in the logs.
yeah. since stalwart dns auto for cloudflare, dont include mx tlsa by default. i need that button
any update about this ? @stalwart
