maxDateTime does not follow standard
The current maxDateTime value of 65534-12-31T23:59:59Z does not conform to RFC 3339 Section 5.6, which mandates exactly 4 digits for the year.
Side note: ISO 8601 allows year values greater than 9999 if agreed upon between sender and receiver, but requires a sign (+/-) prefix for such values.
As a result, the current value is rejected by conformant parsers, such as Java’s Instant.parse.
Expected behavior
maxDateTime has a year with exactly 4 digits, as required by spec
Fixed in v0.16.13 which will be released this week.
