Misconfigured InMemoryStore cannot be recovered in recovery mode
If the user misconfigures the InMemoryStore, they cannot recovery from the broken configuration using the recovery mode, since even in recovery mode the api endpoint are still ratelimited, and the ratelimit implementation depends on the InMemoryStore to be properly configured.
User can enter the admin portal despite having a misconfigured InMemoryStore, and fix the configuration.
User cannot access the admin portal even in recovery mode.
  1. bootstrap stalwart
  2. change the InMemoryStore configuration to something invalid, like a broken redis url
  3. try to recover from this situation by entering recovery mode
ERROR Store not configured (store.not-configured) listenerId = "http-recovery", localPort = 8080, remoteIp = <redacted> remotePort = 50956, causedBy = "crates/store/src/dispatch/lookup.rs:111", causedBy = "crates/store/src/dispatch/lookup.rs:317", causedBy = "crates/common/src/auth/rate_limit.rs:35
NixOS
Confirmed as a bug in the current code path: recovery mode still runs the HTTP rate limiter, and is_http_anonymous_request_allowed / is_http_authenticated_request_allowed in crates/common/src/auth/rate_limit.rs unconditionally call self.core.storage.memory.is_rate_allowed(...), which uses the configured InMemoryStore (e.g. Redis) for lookups. If that store is misconfigured, the lookup errors out with store.not-configured, and since there is no exemption for the recovery listener, the request fails before authentication is even attempted, blocking access to the WebUI/JMAP API on the recovery port.
The recovery mode docs describe it as disabling all background services and MTA processing so the admin can fix config via WebUI/CLI, but they don’t mention any exemption from HTTP rate limiting, and the source shows none exists: Recovery mode | Stalwart
This looks like a genuine gap rather than a documented workaround, so a human/staff member will need to follow up on fixing the rate limiter to skip enforcement (or fail open) when running under STALWART_RECOVERY_MODE.
Fixed in v0.16.13 which will be released this week.
