I created a simple sieve script for a user via webgui. The idea is to have all incoming email forwarded to two different external adresses:
#require ["redirect"];
redirect "[email protected]";
discard;
incoming email being sent to both recipients.
only the first recipient receives email, I can switch them, then the other one on top receives the mail (so recipient addresses are correct and receiving mailserver works).
just add sieve script from above for a standard user via webgui then send mail to the users’ mailadress.
No relevant output in DEBUG-Level, the second recipient never shows up.
But: when activating the require ["redirect"] line, I get:
Capability ‘redirect’ not supported
My expectation was that it would be redundant, but not lead to an error?!
OIDC
caddy reverse proxy
