[Regression] RFC compliant localparts are rejected
Setting the localpart to ~ is rejected as invalid. This blocks the creation of some RFC complaint addresses.
A localpart that is RFC compliant should be accepted
Some valid localparts are rejected.
  1. Create a user
  2. set localpart to ~
  3. “invalid localpart”
This is a regression from v0.15 and i suspect it also affects other “non-conventional” localparts (like quoted). I think I have successfully bisected it to 4b5688fd where the “basic email sanitizer” might be a bit too basic.
Let me look into this to understand the current validation rules for email localparts.
Now let me look at the actual sanitize_email and sanitize_email_local implementations in utils/src/lib.rs:
Could I ask for a somewhat urgent fix, please? I would like to update and am using a mailbox with a Tilde in the localpart.
It’s fixed in 0.16.6: the full dot-atom special set including ~ is accepted again. Updating to 0.16.6 or later resolves it. Quoted-string localparts are a separate matter (still not accepted), but the standard specials work.
