I am trying to test a push service for JMAP email client (bulwark) and I have stumbled on a overquota error for PushSubscriptions. No matter if i up the limit or not, it will not allow for anymore push subscriptions. The error i get is
PushSubscription/set create failed type “overQuota” Description “There are too many subscriptions, please delete some before adding a new one”
From the documentation, the pushsubscriptions are created per user, and testing a new blank server, I have been able to successfully set up push notifications. Is there a way to remove all current PushSubscriptions so I can create new ones with the current server?
Good - I have enough context to give a solid answer. The source code confirms:
- Standard JMAP
PushSubscription/set with destroy works to delete subscriptions.
- When doing a
PushSubscription/get with no IDs (i.e. "ids": null), you get all current subscriptions back, which you can then destroy.
- The quota is checked against non-expired subscriptions (expired ones are pruned automatically when you do a
get).
Here is how to resolve this:
Step 1 – list all your current subscriptions (as the affected user):
curl -X POST https://mail.example.com/jmap \
-H 'Authorization: Bearer $TOKEN' \
-H 'Content-Type: application/json' \
-d '{
"using": ["urn:ietf:params:jmap:core", "urn:ietf:params:jmap:push"],
"methodCalls": [
["PushSubscription/get", { "ids": null }, "c1"]
This returns all subscriptions with their IDs. It also triggers a purge of any already-expired entries, which may free up quota on its own.
Step 2 – destroy the ones you no longer need:
Take the id values from the response and pass them to PushSubscription/set:
-d '{
"methodCalls": [
["PushSubscription/set", {
"destroy": ["<id1>", "<id2>"]
}, "c1"]
A few things to note from the source code:
- The
$TOKEN must belong to the same user account whose subscriptions you want to manage – PushSubscription operations are scoped per user (no accountId parameter).
- Subscriptions automatically expire after at most 7 days, so any stale ones from testing will clean themselves up on the next
PushSubscription/get call.
- If you want to raise the per-user limit, that is controlled by the
MaxPushSubscriptions object quota, which can be adjusted via the WebUI or JMAP API.
hmm assuming the $token is an API key with the correct permissions, i get an error 400…a little stuck here.
Is an API key OK as the $TOKEN or should I be using something else?
The error i get is…
{“type”:“urn:ietf:params:jmap:error:notRequest”,“status”:400,“detail”:“{\n \“using\”: [\“urn:ietf:params:jmap:core\”,\“urn:ietf:params:jmap:push\”],\n \“methodCalls\”: [\n [\“PushSubscription/get\”, { \“ids\”: null }, \“c1\”]\n ]\n }”}
Figured it out.
Does not exist and threw the error. removing it from the CURL command for both returned the push subscription IDs and deleted the subscriptions
