requireClientRegistration with WebUI (Obsolete docs?)
I’m trying to use the requireClientRegistration: true setting on the OidcProvider singleton with the Stalwart WebUI.
The docs Dynamic Registration | Stalwart mention having to create an OAuthClient with clientID: webadmin and redirectUris: ["stalwart://auth"] in this scenario. Which leads to user accounts not being able to login on e.g. https://mail.domain.tld/account.
They just get a red error “Token exchange failed: 400 Bad Request” and the browser console shows response {"error":"invalid_request"} for the POST to https://mail.domain.tld/auth/token
Instead I had to create an OAuthClient with clientID: stalwart-webui and redirectUris: ["https://mail.domain.tld/account/oauth/callback", "https://mail.domain.tld/admin/oauth/callback"].
If desired I can prepare a PR to the website repo.
Stalwart version: 0.16.8 (Docker)
You’ve correctly identified that the documentation is out of date. Here’s what the source code actually shows:
The current WebUI uses stalwart-webui as its client ID, not webadmin. The redirect URI is dynamically constructed as {origin}{basePath}/oauth/callback, which for a standard deployment would produce URLs like https://mail.domain.tld/account/oauth/callback and https://mail.domain.tld/admin/oauth/callback – exactly what you found.
Specifically, in src/services/auth/oauth.ts:
const CLIENT_ID = (import.meta.env.VITE_OAUTH_CLIENT_ID as string) || 'stalwart-webui';
function getRedirectUri(): string {
  const basePath = getBasePath();
  return `${window.location.origin}${basePath}/oauth/callback`;
So when requireClientRegistration: true is set, the correct OAuthClient to register is:
Field Value
clientId stalwart-webui
redirectUris ["https://mail.domain.tld/account/oauth/callback", "https://mail.domain.tld/admin/oauth/callback"]
The docs page at Dynamic Registration | Stalwart still references webadmin and stalwart://auth, which is stale. Your observation is correct and a documentation correction is needed.
A human staff member will follow up on the doc update.
Thanks for the report, the documentation has been updated.
