Sieve behaves unexpected
When using sieve scripts, variables are expected to be valid inside the script. The following script is being used:
require “copy”;
require “mailbox”;
require [“fileinto”,“imap4flags”,“enotify”,“variables”];
set “addresses” “:test1.com:test2.com:test3.com:test4.com:test5.com:”;
if address :domain :matches “To” “*” { set “domain_to” “${1}”; }
    fileinto "testdomainto/${domain_to}";
    if string :contains "${addresses}" [":${domain_to}:" ]
            if string :matches "${domain_to}" "*.*" { set "folder" "${1}"; fileinto "Folder-set/${folder}";}
            fileinto "Result/${folder}";
            stop;
with the email of:
To: [email protected]
Subject: Hello from Sievepad
Date: Mon, 14 Sep 2026 10:00:00 +0000
Message-ID: [email protected]
Content-Type: text/plain; charset=“utf-8”
Hello! This is a test message.
  1. mail will be filed into “testdomainto/test1.com”
  2. mail will be filed into “Folder-set/test1”
  3. mail will be filed into “Result/test1”
  1. mail will be filed into “testdomainto/”
  1. create the user script as shown above
  2. run the sievpad.com testing environment
MySQL
MySQL
Fixed in v1.0.0 (expected for end of this month or early November).
