while importing messages using Vandelay, I get several errors like this:
blob upload failed: single object exceeds the server size limit and cannot be split: blob upload of 85778777 bytes exceeds maxSizeUpload (50000000); exceeds the target server size limit, so this message is skipped and re-running will not migrate it
I tried to increase Email.maxMessageSize , Email.maxAttachmentSize and Imap.maxRequestSize as well as the reverse proxy’s request limit, but it’s still happening. I also looked into the source code and found maxSizeUpload inside CoreCapabilities but I didn’t understand where the setting comes from.
What size limit do I need to set in order to allow imports of larger emails?
