Split Google Workspace tenant
Hello,
I have a client with 1500 Google Workspace accounts.
The solution is starting to get expensive for them, at €18 per month per user.
Many of their users don’t need all the Google services, but only an email address to register for the car manufacturers’ training programs.
I’m looking for a solution to offer them a split domain with Google Workspace accounts and Stalwart accounts.
Has anyone already implemented a similar solution?
How do I manage the email flow between the two solutions? Should I route all emails to Stalwart and forward some to Google Workspace, or vice versa?
I’m using an enterprise version of Stalwart.
This is a well-supported pattern in Stalwart and the recommended architecture is: Stalwart as the inbound MX front-end, with split-delivery relaying for Google Workspace users. Here is how it works:
Recommended architecture
Point your domain’s MX record(s) to Stalwart. Stalwart then acts as the authoritative receiver for your domain and decides per-recipient where to deliver:
  • Stalwart-hosted users (the light email-only accounts) are delivered locally.
  • Google Workspace users are relayed upstream to Google’s SMTP inbound gateway.
This is exactly what Stalwart calls split-delivery relaying.
Step-by-step configuration
1. Enable split-delivery on the Domain object
In the WebUI go to Management > Domains, edit your domain, and set allowRelaying to true. With this flag set, if an incoming recipient is not found in the local directory, Stalwart accepts the message and relays it rather than rejecting it with an “unknown recipient” error.
2. Create a Relay MtaRoute pointing to Google Workspace
Google Workspace accepts inbound SMTP at aspmx.l.google.com (port 25) or, if you use Google’s “dual delivery” feature, at alt1.aspmx.l.google.com. Create a Relay route in Settings > MTA > Outbound > Routes:
  "@type": "Relay",
  "name": "google-workspace",
  "address": "aspmx.l.google.com",
  "port": 25,
  "protocol": "smtp",
  "implicitTls": false,
  "allowInvalidCerts": false,
  "authSecret": {"@type": "None"}
Also create your standard Local and Mx routes if not already present.
3. Wire up the outbound strategy expression
On the MtaOutboundStrategy object, set the route expression to select 'google-workspace' for the recipients that belong to Google, 'local' for Stalwart accounts, and 'mx' for everything else. The simplest approach is: if the recipient resolves locally, use Local; otherwise (the fallthrough from allowRelaying) route via the Google relay.
Important practical notes
  • Google’s dual delivery / split delivery feature: Google Workspace itself has a “Split delivery” setting under Apps > Google Workspace > Gmail > Advanced settings. You should configure it there as well, so that mail originating inside Google (user-to-user) also follows the same routing. Otherwise Google-side users emailing a Stalwart-side address may go into a loop.
  • DNS: Only one set of MX records can point to Stalwart; Google must no longer be a secondary MX or mail will bypass Stalwart for Google-hosted users.
  • Directory: Keep only your light (Stalwart-hosted) users in the local directory. Google Workspace users should deliberately not exist there, so the allowRelaying fallthrough kicks in and forwards to Google.
Relevant docs:
Yes, this works. The cleanest setup is to make Stalwart the authoritative inbound MTA for the domain, host the email-only users as local Stalwart accounts, and route recipients that aren’t local to Google Workspace via an outbound MTA route/smart host to Google’s MX (stalw.art/docs/mta/outbound/routing). Addresses with no local account get relayed to Google; avoid a catch-all that would swallow the Google users. The inverse (Google authoritative, forwarding a subset to Stalwart) is possible but harder to keep clean with loops and SPF/DKIM alignment.
Two things to confirm so I can give you exact route config: which side will own the domain’s MX (be the inbound MTA), and is the split per whole mailbox or do individual users need mail on both? Either way, make sure both sending paths are authorized in SPF/DKIM/DMARC.
