I’m trying to back up my configuration using stalwart-cli via the following command:
stalwart-cli snapshot \
Tenant Domain DkimSignature AcmeProvider Certificate Role \
Account Directory \
SystemSettings DataRetention \
PublicKey DnsServer \
--output "backup-$(date +%Y-%m-%d).ndjson" \
--url https://<url> \
--api-key <key>
However I get the following error:
unexpected server response: no schema available for x:DnsServer
If I remove DnsServer from the snapshot group I get another error:
Domain references DnsServer but DnsServer is not in the snapshot selection
(It works when I add DnsServer to --allow-unresolved but I’m not sure if that’s the correct solution)
Created backup file without error messages.
No Backup is created because of missing schema or reference.
Relaxed / follow up to (automatic) Server backup - RocksDB
Let me look into this snapshot issue with the CLI.
The issue has two parts, and the docs clarify both.
1. no schema available for x:DnsServer
This error means the CLI version you are running does not yet include the DnsServer schema locally (it was added in a later CLI release). Updating stalwart-cli to the latest binary should resolve this.
2. Domain references DnsServer but DnsServer is not in the snapshot selection
This is the expected dependency-closure check. Domain objects hold a reference to DnsServer, so DnsServer must be included in the snapshot selection. The documented “Configuration backup” command in the snapshot docs explicitly includes DnsServer in the selection alongside Domain:
Tenant Domain Directory DkimSignature AcmeProvider Certificate DnsServer Role \
Account \
SystemSettings DataRetention BlobStore InMemoryStore SearchStore \
--allow-unresolved PublicKey \
Note that compared to your command:
DnsServer is listed alongside the other types (not in a separate group), so the dependency resolver sees a complete closure.
PublicKey is placed in --allow-unresolved (not in the main selection), because it does not have a full schema of its own and is referenced but not directly snapshotted.
So the short answer is: include DnsServer in the main selection (which you already tried, but the schema error is a CLI version issue), and move PublicKey to --allow-unresolved.
Docs reference: Exporting server state - snapshot
Thanks, it was an issue with the version of stalwart-cli. I’ve been running 1.0.4 and with 1.0.8 it worked as expected.
What’s the best way to update stalwart-cli (or check for available updates)? I added the Linux (shell installer) in front of my backup script so that it always uses the latest version, but surely that’s not the best solution.
