Stalwart evaluation questions
Dear Stalwart Labs Support Team,
We have been conducting evaluation of Stalwart Mail Server.
Our environment consists of:
• Stalwart Mail Server v0.15.5 on Rocky Linux
• 389 Directory Server (LDAP) for authentication
• Roundcube Webmail (Kolab calendar plugin)
• 18 user accounts
• Apple Mail, Thunderbird, Android (DAVx⁵), iPad clients
During our evaluation we encountered the following issues and would appreciate your technical insight and guidance.
ISSUE 1 — Mailing List / Group Email Delivery with LDAP
Problem:
We have LDAP groups (objectClass: groupOfUniqueNames) with
member emails stored as uniqueMember attributes. When sending
email to the group address (e.g. [email protected])
the Stalwart API returns “notFound” and mail is not delivered
to group members.
What we tried:
• Set directory.ldap.attributes.groups = “uniqueMember”
• Set directory.ldap.filter.list = “(objectClass=groupOfUniqueNames)”
• Added multiple mail attributes on the LDAP group entry
• Created internal mailing list via Web Admin API
• Attempted composite directory (ldap + internal) — auth failed
Current behaviour:
Stalwart resolves the group email via LDAP SEARCH correctly
(ldapsearch returns the group with all members) but the
Stalwart principal API returns {“error”: “notFound”} for
the group email address.
Question:
Is LDAP group expansion (groupOfUniqueNames → multiple
delivery targets) supported in v0.15.5? If yes, what is
the correct configuration? If not, is this planned for
a future release?
ISSUE 2 — Two-Factor Authentication (2FA) with LDAP
Problem:
2FA cannot be configured via the Web Admin UI when using
an LDAP directory. The self-service portal and Web Admin
2FA management are only available for the internal directory.
Additional limitation:
Even if 2FA is manually enabled by adding OTP Auth URL
to LDAP account secrets, it is only usable with mail
clients that support OAUTHBEARER or XOAUTH2. Standard
IMAP clients (Apple Mail, Thunderbird) use basic
authentication and would require entering a new TOTP
code on every mail check — which is impractical.
Question:
Is there a supported method to enable 2FA for LDAP users
that works with standard IMAP clients? Are there plans
to support 2FA management via Web Admin for LDAP
directory in a future release?
ISSUE 3 — ActiveSync (EAS) Not Supported
Observation:
Stalwart does not support Microsoft ActiveSync (EAS)
protocol. This means:
• No push email to mobile devices (iOS/Android)
• No OTA calendar/contacts sync via native iOS Mail
• No remote device wipe via mail server
• No MDM policy enforcement
Workaround we implemented:
DAVx⁵ app on Android for CalDAV/CardDAV sync.
iOS native CalDAV/CardDAV accounts for calendar and
contacts sync.
Question:
Are there plans to support ActiveSync or a similar
push protocol
ISSUE 4 — Calendar Sharing (Boss/PA Model)
Problem:
No calendar sharing option available
Question:
Is calendar sharing by stalwart?
ISSUE 5 — Roundcube Calendar vs CalDAV Sync
Observation:
The Kolab calendar plugin for Roundcube uses a database
driver (MySQL) and does not sync with Stalwart’s native
CalDAV store. Events created in Roundcube are stored in
MySQL and are not visible to CalDAV clients (Apple
Calendar, Android DAVx⁵, Thunderbird) and vice versa.
Question:
Is there a recommended CalDAV-capable calendar plugin
for Roundcube that works with Stalwart’s CalDAV store?
Or is there a plan to provide a native Stalwart webmail
with full CalDAV integration?
ISSUE 6 — Role-Based Administration (RBAC)
Observation:
The Web Admin only supports all-or-nothing admin access.
There is no way to create a helpdesk role (password
reset only), read-only auditor role, or compliance
officer role with access to mail logs only.
Question:
Are there plans to support role-based administration
ISSUE 7 — No Message Recall / Unsend
Observation:
Stalwart does not support message recall or unsend
functionality. Once an email is sent — whether to an
internal or external recipient — it cannot be recalled
or retracted by the sender or administrator.
Enterprise mail platforms such as Microsoft Exchange
and Google Workspace support message recall for
internal recipients. This is a frequently requested
feature by end users.
Question:
Is message recall planned for a future release?
Is it possible to implement via Sieve scripting
or any other existing mechanism?
ISSUE 8 — No Scheduled Send
Observation:
Stalwart does not support scheduled email delivery
(compose now, send later). This feature is available
in Outlook, Gmail and most enterprise mail clients.
It is not available in Roundcube webmail or via IMAP
on Apple Mail, Thunderbird, or mobile clients when
connected to Stalwart.
Question:
Is scheduled send planned for a future release?
Could this be implemented via Sieve or JMAP?
ISSUE 9 — Mail Journaling Limitations
Observation:
We successfully implemented mail journaling using a
system-level Sieve script that BCC copies all messages
to a dedicated journal mailbox ([email protected]).
However this implementation has the following limitations:
  1. Single mailbox destination — all mail (inbound and
    outbound from all users) goes into one shared mailbox.
    There is no per-user or per-domain journal segregation.
  2. Not tamper-proof — an administrator can disable the
    Sieve script at any time. There is no audit trail
    for changes to the journaling configuration itself.
  3. No metadata enrichment — the journal copy does not
    include delivery metadata (sender IP, relay path,
    authentication method) that would be required for
    compliance purposes.
  4. Not a Legal Hold — the journal mailbox can be
    accessed and deleted by any admin. There is no
    immutable storage or hold mechanism.
Question:
Is there a plan to implement native mail journaling
with per-user segregation, tamper-proof storage, and
compliance metadata? Is Legal Hold on the roadmap?
ISSUE 10 — AI-Powered Features Clarification
Observation:
The Enterprise compare page lists AI-powered features
We would like to understand these better.
Questions:
  1. Are the AI features active in our current v0.15.5
    Enterprise trial license?
  2. Does the LLM spam classifier require additional
    configuration or is it enabled by default?
  3. Do AI-powered Sieve scripts require an external
    API key (OpenAI/Anthropic) or is a pre-trained
    model included with the Enterprise license?
  4. What is the approximate resource impact (CPU/RAM)
    of enabling LLM classification on an 18-user setup?
ISSUE 11 — No Room & Resource Booking
Observation:
Stalwart does not support room and resource booking.
and Google Workspace allow administrators to create
bookable resources (meeting rooms, projectors, vehicles,
equipment) that users can reserve directly when
scheduling calendar events.
Specifically what is missing:
• No resource mailbox / resource calendar type
• No auto-accept / auto-decline for resource conflicts
• No room availability lookup when scheduling meetings
• No resource capacity or policy enforcement
• No resource directory for users to browse
Question:
Is room and resource booking planned for a future
release?
We would greatly appreciate your technical guidance
on the above issues and your roadmap for the features
mentioned.
License Reference : softcell.in
Subscription Ref : 1656
Stalwart Version : 0.15.5
OS : Rocky Linux
Directory : 389 LDAP
Users : 18 mailboxes
Clients tested : Apple Mail, Thunderbird, Android,
iPad, Roundcube Webmail
Thank you for your time and continued support.
A lot of these answers change between 0.15.5 and 0.16, so the first thing I would suggest is to evaluate on 0.16.x rather than 0.15.5; the migration is non-trivial but the feature surface is meaningfully different and a number of items below only have a useful answer on 0.16.
  1. LDAP group expansion. Supported, but the directory configuration needs attributes.groups and the per-group mail (or whichever attribute holds the delivery address) to be resolvable. The “notFound” you are getting from the principal API for the group address points at the directory not returning that record under the principal-lookup filter, which is a different filter from the group-search one. Easiest path: post the relevant lines of directory.ldap.filter.principal and we can fix the filter.
  2. 2FA with LDAP. Manageable only via OAUTHBEARER/XOAUTH2 capable clients today, as you noted. Web-UI 2FA management against an LDAP directory is on the backlog. The IMAP-basic-auth-plus-TOTP-every-poll pattern is intentionally not supported; the alternative pattern is per-client app passwords (which can be issued post-2FA-login from the web UI), which is what most teams converge on.
  3. ActiveSync. No, and no plans. JMAP-push is the supported alternative; clients that don’t speak JMAP get CalDAV/CardDAV + IDLE on IMAP, which DAVx⁵ on Android and the iOS native stack both handle.
  4. Calendar sharing. Supported in 0.16 (per-calendar ACL with Read/Write/FreeBusy options).
  5. Roundcube CalDAV. The Kolab plugin is its own MySQL-backed store and won’t talk to Stalwart’s CalDAV. The current CalDAV-capable plugin for Roundcube is roundcube-plugin-calendar (the Kolab fork in CalDAV mode, or the recent roundcube-caldav-bridge add-on); both have rough edges. Realistically, the path most operators are taking is a JMAP-native webmail (root-fr/jmap-webmail is one community client; Bulwark is the Stalwart-leaning one) plus retiring Roundcube.
  6. Role-based administration. Partial in 0.16 via the permission grid (~80 fine-grained permissions assignable per role).
  7. Message recall. No, and no plans. Recall is fundamentally a client-side coordination feature that requires either trusted clients or a proprietary protocol; Exchange’s “recall” only works inside a single Exchange organization and even there is unreliable.
  8. Scheduled send. JMAP supports MailMessageSubmission with sendAt; the JMAP-side implementation in Stalwart is there in 0.16. From a client, you need a client that exposes the field (Bulwark does; vanilla Roundcube/Apple Mail do not). IMAP has no equivalent.
  9. Journaling. The Sieve-based BCC is the supported pattern today, with the limitations you listed. Native journaling with per-user segregation, immutability, and metadata enrichment is on the roadmap as “Compliance journaling” but is not in any released version.
  10. AI features. They live on the Enterprise tier. The LLM spam classifier in particular requires an API key for the chosen provider (OpenAI, Anthropic, or a local OpenAI-compatible endpoint) and is opt-in per-domain. Resource impact for 18 users with cloud providers is negligible on Stalwart’s side; the cost is the per-token bill from the provider. Pre-trained local models are not bundled.
  11. Room/resource booking. Partial in 0.16 (a calendar with a resource type and auto-accept policy is configurable; resource directory and capacity rules are not yet); not in 0.15.5.
If you can move the evaluation to 0.16.x, questions 4, 6, 8, and 11 turn from “no” into “partial/yes”, and 1 becomes easier to debug.
I’m also interested in a room/resource booking. I checked the source code of Stalwart 0.16.8 but I couldn’t find anything related to this?
What do you mean by this is partially implemented.
