Stalwart v0.16.6 released
[0.16.6] - 2026-05-20
If you are upgrading from v0.16.x, replace the binary (or run docker pull). If you are upgrading from v0.15.x and below, please read the upgrading documentation for more information on how to upgrade from previous versions.
Added
  • Added 58 new DNS provider integrations (see dns-update crate for details).
  • DNS updater: Log DNS record types and values.
  • Sieve: Allow User Sieve scripts to access orcpt.
  • MTA: Log when messages are rejected or discarded by the spam classifier.
Changed
Fixed
  • DAV: acl-principal-prop-set REPORT enforced the wrong privilege.
  • JMAP: Thread/get did not filter by per-mailbox ACLs on shared accounts.
  • IMAP: UID FETCH N:* could miss messages moved into a SELECTed mailbox by another connection.
  • DNS updater:
    • Skip v=spf1 a -all records for apex domains.
    • RFC2136 TSIG: regression related to multiplexer.
    • Route53: Chunk TXT records when they exceed 255 characters.
  • ACME:
    • Update defaultCertificateId when renewing a certificate that is currently set as default.
    • Perform DNS-01 authorizations sequentially to avoid race conditions in some DNS providers.
  • Allow internal TLDs and special characters in e-mail addresses.
  • Websocket: Perform case insensitive matching during upgrade.
  • LDAP: Synchronize accounts when expanding mailing list recipients.
  • Sieve: replace action adds an extra From header.
  • ACL: Orphaned ACL entries for deleted accounts cause JMAP session errors.
