Step by step upgrade from v0.15.x to v0.16.x
Helpbot please give me step by step instructions to upgrade from v0.15 to v0.16 without backup. I am using Debian 13.
I have the binary in opt/stalwart-mail/install
Thank you ideer2 for the link to the update and for trying to help.
I read those instructions multiple times but there is so much info that it is a bit confusing to me. I was looking for straight forward directions with binary not docker. And I don’t need a backup because I take a snapshot of the server and can go back to previous time no problem.
I was hoping for the bot to reply to my question.
Or perhaps someone would like to help by replying with instructions on how to update step by step in Debian 13 binary from v0.15 to v0.16. No need for backup.
Please can someone confirm I have these steps correct for upgrading my mail server:
  1. Download the script from the Stalwart repository:
$ curl -fLO raw.githubusercontentDOTcom/stalwartlabs/stalwart/refs/heads/main/resources/scripts/migrate_v016.py
  1. Create a Python virtual environment
$ python3 -m venv .venv
$ source .venv/bin/activate
(.venv) $ pip install requests urllib3
  1. Dump the live v0.15.x settings
(.venv) $ python migrate_v016.py dump
–url mail.exampleDOTcom
–username admin
–password adminPassword
–settings settings.json
–principals principals.json
  1. Convert the dump to the new format
(.venv) $ python migrate_v016.py convert
–config config.json
–output export.json
  1. I WILL SKIP THE BACKUP OF THE DATABASE
  2. Perform the migration
6a. Download the v0.16 binary. Grab the release matching the target platform from githubDOTcom/stalwartlabs/stalwart/releases/latest. Do not replace the running binary yet.
6b. Stop the old service.
$ sudo systemctl stop stalwart
  1. Back up the old binary and install the new one
$ sudo mv /usr/local/bin/stalwart /usr/local/bin/stalwart.v015
$ sudo mv /path/to/downloaded/stalwart /usr/local/bin/stalwart
$ sudo chmod 0755 /usr/local/bin/stalwart
$ sudo chown root:root /usr/local/bin/stalwart
  1. Install the new config.json
$ sudo mv /path/to/config.json /etc/stalwart/config.json
$ sudo chown stalwart:stalwart /etc/stalwart/config.json
$ sudo chmod 0640 /etc/stalwart/config.json
  1. Start the new binary in recovery mode from the foreground
$ sudo -u stalwart env
STALWART_RECOVERY_MODE=1
STALWART_RECOVERY_ADMIN=admin:someTemporaryPassword
/usr/local/bin/stalwart --config=/etc/stalwart/config.json
  1. Apply the exported snapshot (this section I am confused)
10a. Install new CLI
curl --proto ā€˜=https’ --tlsv1.2 -LsSf
githubDOTcom/stalwartlabs/cli/releases/latest/download/stalwart-cli-installer.sh | sh
10b. apply snapshot
$ export STALWART_URL=://127.0.0.1:8080
$ export STALWART_USER=admin
$ export STALWART_PASSWORD=someTemporaryPassword
$ stalwart-cli apply --file /path/to/export.json
  1. Reconfigure the service manager
11a. For systemd (typically /etc/systemd/system/stalwart.service), locate the ExecStart= line and change the --config= argument:
ExecStart=/usr/local/bin/stalwart --config=/etc/stalwart/config.json
11b. Then reload the unit:
$ sudo systemctl daemon-reload
  1. Start the service.
$ sudo systemctl start stalwart
  1. Post-migration tasks
13a. Log in to the admin panel
mail.example.org/admin
  1. Recalculate disk quotas
  2. Create a permanent administrator
Create a real administrator account through Management → Accounts, verify the new account can log in, and then remove STALWART_RECOVERY_ADMIN from:
the systemd environment file (for example /etc/stalwart/stalwart.env) and restart the service, or
the init.d defaults file, and restart the service
  1. DONE
Can someone please confirm these are the right steps for me to upgrade from v0.15 to v.016 with Debian 13 with the binary (not docker). Am I missing any steps here?
I know I can test it but I just want to get some guidance from more experienced forum friends before I do this at 2 am on a weekend. I only have 6 email accounts and one domain. I have this mail server for my family.
I deleted the https from the post because it will only allow 2 links.
Thanks.
The canonical procedure is UPGRADING/v0_16.md in the repo, and it has an ā€œOption A: Binary deployments (systemd/init.d)ā€ section that’s exactly your case. Condensed, for a Debian binary install already on 0.15.x:
  1. With 0.15 still running, grab resources/scripts/migrate_v016.py, make a venv, pip install requests urllib3, then run it in dump mode (your URL, admin user/pass) to produce settings.json and principals.json, then convert mode to produce config.json and export.json.
  2. First, one important point: the 0.16 first-start irreversibly wipes the old config and directory records and resets quotas. Your data on disk survives, but you do need a rollback point. Your server snapshot counts as that backup, so you’re fine as long as you can roll back to it if needed; don’t skip that.
  3. Stop the 0.15 service (systemctl stop stalwart), keep the old binary, install the 0.16 binary into your /opt path, and put the generated config.json where the old config lived.
  4. Start once in the foreground in recovery mode as the stalwart user: STALWART_RECOVERY_MODE=1 STALWART_RECOVERY_ADMIN=admin:tempPass /opt/…/stalwart --config=/etc/stalwart/config.json. It wipes the incompatible subspaces, migrates the spam model, and listens only on 8080.
  5. From another terminal, with stalwart-cli 1.0.2+ and STALWART_URL=http://127.0.0.1:8080, run stalwart-cli apply --file export.json.
  6. Ctrl+C the foreground server, update your systemd unit’s --config to the new config.json, remove the recovery env vars, and systemctl start stalwart. Then recalc disk quotas from the WebUI.
I’d genuinely recommend dry-running this on a throwaway 0.16 first, because the config model changed completely (no TOML, accounts must be user@domain, the old /api is replaced by JMAP). Full doc: stalwart/UPGRADING/v0_16.md at main Ā· stalwartlabs/stalwart Ā· GitHub.
As always, thank you Stalwart Team for taking the time to reply to my question and for numbering the steps I am to follow. I will definitely try these instructions to update to v0.16 this weekend. Per your recommendation, I will dry-run this on a throwaway 0.16 first.
Tried to upgrade but failed. I was able to do step 1-3 but I could not do step 4.
Start once in the foreground in recovery mode as the stalwart user: STALWART_RECOVERY_MODE=1 STALWART_RECOVERY_ADMIN=admin:tempPass /opt/…/stalwart --config=/etc/stalwart/config.json..
I kept getting a message ā€œsudo -u stalwart env does not exist or command not foundā€
My v0.15 installation is in:
/opt/stalwart-mail/bin ../data ../etc ../logs
and my binary name is: stalwart-mail (not stalwart).
Perhaps it is better for me to do a full reinstallation of Stalwart v0.16 since I only have a few email accounts and one domain. I don’t mind starting from 0 by completely uninstalling v0.15 from my linux server and running the installation script again as I don’t need the emails in the current installation. Before I do I want to ask this question: Is there a way to keep the same dkim in the new installation from a previous installation?
I can recreate the domain and emails in the new installation but would like to keep the same dkim settings so I don’t have to update the DNS records. The reason I want to keep the same dkim record is because all my emails are successfully arriving in the inbox of all the major email providers. Perhaps getting a new dkim has not impact but I just want to check first.
Thanks!
4th of July weekend and with good luck I was able to upgrade my v0.15.5 to v0.16.11. I followed the instructions from Stalwart and I used an AI platform (not going to name here) and it gave me many instructions. It took me 2 hours of tinkering here and there and restoring a couple of snapshots and I finally got it working. Version 0.16.x is really nice.
LOVE STALWART MAIL!!!
