Sudden issue with bad signature on default certificate for domain. v0.15.3
Connecting using TLS fails, ACME appears to be working fine.
Should be able to send and receive mail via TLS ports.
40E7EF2F2A7F0000:error:0A00007B:SSL routines:tls_process_cert_verify:bad signature:../ssl/statem/statem_lib.c:545:
Reload and restarting produces the same results.
v0.15.x
Built from source
FoundationDB
FoundationDB
The OpenSSL error tls_process_cert_verify:bad signature means the public certificate and private key stored on the server do not match – the server is presenting a certificate signed by one key while holding a different private key. ACME appearing to work does not rule this out; it only means the challenge/renewal process completed, but the stored certificate and key pair could have become mismatched (e.g., a new key was generated on renewal but the old certificate – or vice versa – is what got persisted).
Here are the most likely causes and what to check:
  1. Certificate/key mismatch after ACME renewal. If ACME renewed the cert but the stored private key in the database is stale (or a different key was stored), the pair will not match. In the WebUI go to Settings › TLS › Certificates and inspect the certificate object. You can verify the match yourself by extracting the public key from both the cert and the private key and comparing them:
    openssl x509 -noout -pubkey -in cert.pem | openssl md5
    openssl pkey -pubout -in key.pem | openssl md5
    Both hashes must be identical.
  2. Manually re-upload a matched pair. If you have a working cert/key pair on disk (from the ACME client’s working directory), you can update the Certificate object via the CLI:
    stalwart-cli update Certificate <id> \
      --field 'certificate={"@type":"Text","value":"<PEM>"}' \
      --field 'privateKey={"@type":"Text","secret":"<PEM>"}'
    Or do it through the WebUI under Settings › TLS › Certificates.
  3. FoundationDB storage issue. Because you are using FoundationDB for blob storage, it is worth checking whether the stored certificate blobs are intact and consistent – a partial write during an ACME renewal could have left a mismatched state.
Note: since this is v0.15.x, the configuration format and management tooling are different from the current release. The above guidance on certificate objects and the CLI applies to the current version; in v0.15 you would manage certificates via the TOML config or the older WebUI. A human contributor familiar with v0.15 will be better placed to advise on the exact recovery path for that version.
Reference: Certificate object docs | TLS/ACME overview
“Bad signature” at this point in the handshake means the client cannot verify the leaf against the chain Stalwart sent: either the chain is incomplete (missing intermediate), or the leaf’s signature was made with a private key that doesn’t match the public key being presented (which is what happens when the cert object and the key get out of sync, usually after a half-completed ACME renewal). v0.15.3 is also a few versions back; the cert-loader has been tightened since.
Two things to check:
  1. Verify the chain you are actually sending: openssl s_client -starttls smtp -connect <host>:25 -showcerts < /dev/null and look for at least two certificates (leaf + intermediate) and that the leaf’s Issuer matches the intermediate’s Subject. If only the leaf comes back, the chain file in your storage doesn’t include the intermediate.
  2. Confirm key/cert are paired: openssl x509 -in leaf.pem -noout -modulus | openssl md5 and openssl rsa -in key.pem -noout -modulus | openssl md5 should print the same hash. If they don’t, ACME rolled the key and the certificate object in the store didn’t get updated.
Ok, the issue seems to be down to this error:
WARN Multiple TLS certificates available total = 36
How do I go about flushing the backlog of certificates?
Stalwart will now automatically update the default certificate id after renewals. That warning you’re seeing is when the client does not provide a hostname during the TLS handshake so Stalwart does not know which certificate to use. This warning can be safely ignored but you might suppress it by setting a default certificate.
