Support DNS management for Domain Aliases
Currently Domains only manage DNS for the primary domain, and do not manage Alias domain DNS records at all.
This is problematic, because e.g. DKIM selectors change over time, so there is no way for DNS administrators to sensibly maintain the DNS records manually, unless their DNS host happens to support some sort of out-of-spec DNS aliasing hacks, which many do not.
Proposed solution
Add a boolean flag to Domain objects to allow enabling alias domain DNS management (default disabled I suppose, to avoid backwards-incompatible updates) which causes Stalwart publish records for alias domains in addition to the primary domain.
Implementation Details
There is a question as to the shape these records should take. I think the simplest path (since it does not require any changes to TLS cert generation, etc) would be to handle various record types as below:
Record Type DNS Record Type DNS Value Notes
DKIM public keys CNAME Point to primary domain selector record
TLSA records Ignored Unnecessary since domain will not receive mail directly
SPF records TXT “include:primarydomain.tld -all”
MX records MX Duplicate primary domain record
DMARC policy TXT Duplicate primary domain record
SRV records Ignored MUAs should connect only to the primary domain
MTA-STS policy record TXT Duplicate the primary domain’s record, additionally setting the mx property to point to the primary domain’s mail exchangers
TLS reporting record TXT Duplicate primary domain records
CAA records Ignored MUAs should connect only to the primary domain
Autoconfig records Ignored MUAs should connect only to the primary domain
Legacy Autoconfig records Ignored MUAs should connect only to the primary domain
Microsoft Autodiscover records Ignored MUAs should connect only to the primary domain
Any thoughts on this? This is blocking migration from LDAP/separate domains (with domain rewrite hacks) to domain aliases on the internal DB due to the DKIM selector issue, and I’d really like not to have to migrate twice (once to v0.16/v1.0, and once to domain aliases) if this has any chance of being resolved in the foreseeable future.
