I’m testing my instance and get no 250-STARTTLS offered.
V: 0.16.7
The most common cause of 250-STARTTLS not being advertised is that no TLS certificate is configured or resolvable for that listener. Stalwart only advertises STARTTLS when it can actually perform a TLS handshake; if the listener has no valid certificate, the extension is silently omitted (and a tls.not-configured error event is logged).
Here are the things to check, in order:
Certificate exists and is assigned. In the WebUI go to Settings › Network › Listeners, open your SMTP/submission listener, and confirm useTls is true (the default). Then check Settings › System Settings and confirm defaultCertificateId points to a valid certificate object.
A certificate object actually has a cert+key loaded. In the WebUI go to Settings › Network › TLS (or the Certificates section) and verify the certificate is present and not expired. If you are using ACME/Let’s Encrypt, confirm the ACME order completed successfully.
Implicit TLS confusion. If your listener has tlsImplicit: true, the connection is TLS from byte one and STARTTLS is intentionally not advertised in the EHLO response (it’s not needed). Port 465 should be tlsImplicit: true; port 587 and port 25 should be tlsImplicit: false (the default).
Check server logs for tls.not-configured. The docs describe this event as: “A TLS connection was requested but no certificate is configured for this listener.” If you see this in the logs, the root cause is a missing or mis-assigned certificate.
