Hi everyone,
This is an update on the DNSSEC and DANE delivery failures reported across several threads here. They come from bugs in hickory, the DNS library Stalwart uses to validate DNSSEC, and each one now has a fix submitted upstream:
- Google Workspace MX hosts (aspmx.l.google.com and the altN hosts) failing with “exceeded max validation depth”: hickory#3974, fixed in #3976 and #4007. Both are merged but not yet in a hickory release.
- Domains delegated two or more labels below an NSEC3 opt-out zone, such as port.venice.it and the comune.*.fr.it municipality domains: hickory#3985, fix in #4001.
- Unsigned zones without an NS record at their apex, for example akokan.pl: hickory#4027, fix in #4028.
- Microsoft 365 hosts (*.mail.protection.outlook.com) failing when the upstream resolver answers SERVFAIL for them, which Google Public DNS and many local resolvers do: hickory#4063, fix in #4064.
- Truncated UDP responses never retried over TCP when several name servers are queried at the same time: hickory#3963, fix in #4062.
- Valid answers rejected because the response also carries an unrelated NSEC record, plus some correctly signed wildcard answers rejected: hickory#4047, fix in #4055.
- Validating queries sent without the CD bit, which makes a validating upstream resolver answer SERVFAIL: hickory#3966, fix in #4014 and #4036.
DANE delivery has been broken for some of you for weeks now, and the hickory maintainers seem to be busy at the moment, so most of these PRs are still waiting for review. We have forked hickory at stalwartlabs/hickory-dns with all of the fixes above applied, and Stalwart will build against that fork until hickory publishes a release that contains all of them. We ran the patched resolver against every domain reported in these threads, with Cloudflare, Google and Quad9 as upstream resolvers, and they all validate correctly now.
v0.16.26 ships with the patched resolver and will be out today or tomorrow. After upgrading you can remove any TLS strategy you added to turn DANE off for specific domains. If a domain still fails after the upgrade, post it in this thread together with the DNS resolver you use and we’ll look into it.
