"upsert" isn't idempotent on MemoryLookupKey object, errors with primaryKeyViolation
With plan:
{"@type":"destroy","object":"MemoryLookupKey","value":{"namespace":"spam-traps"}}
{"@type":"upsert","matchOn":["namespace","key"],"object":"MemoryLookupKey","value":{"lk-a":{"key":"[email protected]","namespace":"spam-traps"}}}
! stalwart-cli apply --file plan.ndjson
Plan: 1 destroy, 0 update, 0 create, 2 upsert, 0 reconcile (2 objects)
✓ destroyed MemoryLookupKey (1)
✓ upserted MemoryLookupKey (1)
✗ upsert MemoryLookupKey: MemoryLookupKey: create failed for lk-a (operation #3): error: primaryKeyViolation | Properties: namespace | Object id: MemoryLookupKey#i2i9w2lsbkqa
Done: 1 destroyed, 0 updated, 1 created (1 failed)
error: MemoryLookupKey: create failed for lk-a (operation #3): error: primaryKeyViolation | Properties: namespace | Object id: MemoryLookupKey#i2i9w2lsbkqa
same happens when there is only a single upsert, and multiple applies happen, two upserts in a single plan is just for reference.
primaryKeyViolation is an error that occurs when upsert tries to create same object multiple times from what I understood, but, upsert shouldn’t create it multiple times, that is why upsert exists, to not error like that…
For other objects upsert works, I had no issues, but for this one doesn’t for some reason.
upsert should be Idempotent
NixOS
This has been fixed in the CLI repository.
