User sieve script
Hello,
I want to specify a user sieve script using the json file. Unfortunately, i havent been to find a way to do that.
Here is my workaround,
SIEVE_SCRIPT='require ["fileinto", "mailbox", "imap4flags"];
if header :contains "X-Spam-Status" "Yes" {
    fileinto :create "Junk Mail";
    setflag "\\Seen";
    stop;
# Upload Sieve script content as a blob (binary content)
BLOB_RESPONSE=$(curl -s -u "[email protected]:$STALWART_CONTACT_PASSWORD" \
  -X POST "$STALWART_URL/jmap/upload/$CONTACT_ACCOUNT_ID/" \
  -H 'Content-Type: application/sieve' \
  --data-binary "$SIEVE_SCRIPT")
SIEVE_RESULT=$(curl -s -u "[email protected]:$STALWART_CONTACT_PASSWORD" \
  -X POST "$STALWART_URL/jmap" \
  -H 'Content-Type: application/json' \
  -d '{
    "methodCalls": [
        "SieveScript/set",
          "create": {
            "spam-filter": {
              "name": "spam-filter",
              "blobId": "'"$BLOB_ID"'",
              "isActive": true
        "c1"
    "using": ["urn:ietf:params:jmap:core", "urn:ietf:params:jmap:sieve"]
if echo "$SIEVE_RESULT" | grep -q '"created"'; then
  echo "Spam filter Sieve script created and activated"
else
  echo "Warning: Sieve script creation may have failed"
  echo "Response: $SIEVE_RESULT"
fi
Is it possible to specify in the json file, so i can use stalwart-cli apply to upload it instead of using a script?
Let me look into what the CLI supports for Sieve scripts.
stalwart-cli apply works with JMAP settings/configuration objects — it is not designed to upload Sieve scripts or binary blobs. Sieve scripts live in the mail data layer (uploaded via JMAP SieveScript/set), not in the server configuration layer, so there is no NDJSON representation that stalwart-cli apply can handle for them.
Your current approach — uploading the blob via the JMAP upload endpoint and then calling SieveScript/set — is the correct, supported way to provision per-user Sieve scripts programmatically. This isn’t covered in the current docs as a stalwart-cli workflow.
A community member or staff member may be able to confirm whether a future CLI path for Sieve script provisioning is planned.
The cli does not support uploading blobs. You’ll have to upload the Sieve blob using curl or with a script.
