when a user tries to login on the portal an additional login mask pops up, but does not work.
I have one user besides the default admin user which works. The difference is, that this user was first logged in version 16.1, and there is an entry for “Authentication Credentials” with “Password for authentication to account” in the user record.
All other users were created with versions greater 16.1 an miss this field.
Creation of that entry is not possible, it gave the error:
“Cannot set credentials for accounts in an external directory.”
also I can’t see LDAP traffic in this case.
Login on imap is of course possible for that user(s), just the portal does not work
User should be able to login
the following error pops up:
Token exchange failed: 400 Bad Request
Back to login
MySQL
LDAP
