Vultr DNS provider fails to publish RSA DKIM TXT record due to split-string quoting
When using the built-in Vultr DNS provider to automatically publish DKIM records, publication of an RSA (2048-bit) DKIM key fails with a 400 BadRequest from the Vultr API.
Successfully publishd the RSA (2048) DKIM TXT record via the Vultr DNS API.
The task fails because the Vultr API rejects the request with a 400 Bad Request, so the record is not created.
  1. Configure the Vultr DNS provider in Stalwart with valid API credentials.
  2. Create a domain and generate an RSA (2048-bit) DKIM signature.
  3. Enable automatic DKIM key rotation/renewal for the domain.
  4. Confirm the scheduled task “Perform DKIM key rotation for a domain” under Tasks → Scheduled.
  5. Monitor the result of that task.
  6. Observe that task fails with the error.
(Contrast) Repeat with an Ed25519 DKIM key — publication succeeds.
Failed to publish DKIM record v1-rsa-20260607-elpf3pan._domainkey..: Failed to set DNS RRSet: API error: BadRequest {“error”:“Unable to add record: Quotes may only appear at the beginning and end of the data”,“status”:400}
MySQL
MySQL
SQL
  • Docker Compose with network_mode: host
  • reverse proxy: none (no reverse proxy)
  • DNS Resolver: local Unbound, used by Stalwart for outbound DNS
Unbound listens on 127.0.0.1 / ::1, port 53535, restricted to localhost
General domains are forwarded over DoT to Cloudflare.
Several DNSBL zones (Spamhaus and etc…) are set as like ‘local-zone: “zen.spamhaus.org” nodefault’
Let me look into the Vultr DNS provider implementation in the Stalwart source code.
A fix will be included in v0.16.9.
